Honda Motorcycles
Navigation » Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda RC51 » rear seat insert problem.
Honda RC51 Discussion of the Honda RC51, Honda SP1, and Honda SP2 Motorcycles.
Old 03-03-2009, 6:53 PM   #1
RipinRC is on a distinguished road
Hey guys i have had my rc for a couple months and the insert where the passenger seat would go is sticking up? theres nothing in the way, it locks, down still, do i need to bend something anybody know? any help is greatly appreciated! thanks!
-nTg-
RipinRC is offline   Reply With Quote
Old 03-04-2009, 2:55 PM   #2
Reputation Power: 4
slammp is on a distinguished road
Re: rear seat insert problem.
It should snap right in and be flat? I would look at the locking mechanism on the cover and see if its bent. Does the passenger seat fit good?
slammp is offline   Reply With Quote
Old 03-12-2009, 4:05 PM   #3
the passenger seat tilts up towards the back as well... ? .? so its the female part of the lock. poooooop i mean it still looks good but i would loook so much better if it was smooth.. ya know? any suggestions?
Old 03-13-2009, 8:05 AM   #4
Reputation Power: 4
If I am thinking correctly here (and I am at work without the bike to actually look at), but the seat has two metal hooks on the front end that wrap around a post and then the rear has a metal loop that snaps down into the locking mechanism.
I would say that if it is fully locked and not flush in the rear, that that locking mechanism is bent up. I would try to bend it down. Take a wood block and place it on the locking mechanism and then hit the wood with a hammer until it goes down. Start out lightly and then check the seat fit, see if it has improved and then go back to hammering it. I would imagine that this would not be too hard to correct, but again I am at my desk so were working off of memory here.
Old 03-14-2009, 10:27 AM   #5
juicedstang999 is on a distinguished road
-nTg-
Was the RC ever crashed? The subframe is probably bent. See if you can loosten up the rear cowl a bit and pull it up and re-tighten the bolts.
That might bring the cover a little closer...
juicedstang999 is offline   Reply With Quote
Old 03-16-2009, 2:57 PM   #6
hey guys slammp thank you i'm going to try that after work today!! and i'll let you know if it works! and no the motorcycle has never been crashed. i have taken this bike apart and put it back together numberous times and it has been like that since i bought it... i will up date later today!!! thanks again!!
-nTg-
Old 04-03-2009, 11:59 AM   #7
craigster is on a distinguished road
I have an 04, and just installed a scorpio alarm. this required the removal of the rear faring to do the Wiring. when put the faring back on I had the same problem you have encountered. try putting the cowl cover back on and pulling up on the tail of the fairing, the tilt will go away and i think you might just have to loosen up the bolts and adjust the pitch of your fairing. hope this helps.
craigster is offline   Reply With Quote
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda RC51
Visitors found this page by searching for:
Nobody landed on this page from a search engine, yet!
You may not post new threads
You may not post replies
[IMG] code is Off
WANTED::: 954rr Upper Fairing, Rear Fairing, and Rear Seat Syris3000 Wanted 3 07-09-2010 11:06 PM
2000 929 Rear Seat Problem Nav Honda FireBlade 10 03-26-2009 8:52 PM
wtb rear hugger and rear seat cowl in 01 929yellow shakey1378 Wanted 4 07-15-2008 10:49 PM
FS - 929 black Sargent Seat w/ rear seat cover OSIRIS For Sale 3 01-04-2007 8:17 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98
