It's doing it again
Old 05-10-2009, 4:47 AM
Bike(s): Honda Sp1, Honda XR400
Rep: PudSP1 is on a distinguished road (10)
It's doing it again
So I had the ECM replaced in my SP1. Now, about 400km later, it starts breaking down again and the FI light keeps coming on. No codes stored in the ECM.........is this thing a lemon or what?
PudSP1 is offline
View PudSP1's Profile View PudSP1's Gallery Find More Posts by PudSP1
Old 05-10-2009, 9:53 PM
Bike(s): 2001 Honda RC51
Rep: fastattack686 is on a distinguished road (10)
Send a message via Yahoo to fastattack686
Re: It's doing it again
After seeing the gremlins Im chasing down............frayed wiring harnesses.. and seeing comments by others with running rough, problems. etc. ........... I would be willing to bet you have a wiring problem that is showing.. Just a guess..
Not easy to trace out or find .. but would start tracking wiring runs..........
Could be in left field.. but think the twin is hard on wiring due to the vibration.......
fastattack686 is offline
View fastattack686's Profile View fastattack686's Gallery Find More Posts by fastattack686
Old 05-10-2009, 10:22 PM
rokitt51's Avatar
Bike(s): 97 YZF1000, 02 954
Rep: rokitt51 will become famous soon enoughrokitt51 will become famous soon enough (111)
Yeah a chaffing problem more than likely. I put the wire protecting plastic all over my harness where i could on my SP2.
rokitt51 is offline
View rokitt51's Profile View rokitt51's Gallery Visit rokitt51's homepage! Find More Posts by rokitt51
Old 06-06-2009, 1:52 AM
Thanks guys, would someone know the week spots in the wiring harness to start looking for rather than looking in the wrong spot first.
PudSP1 is offline
Old 06-06-2009, 3:56 AM
I suppose i should give a little more information with regards to it 'breaking down'. The bike runs fine for about 20 - 30 minutes then the engine shuts down for about half a second, at the same time the FI light comes on. Then it runs fine until it does it again, this could take up to 5 km's. The further it is riden, the more often it does it until it is almost every 20 seconds. I'm about to disconnect the PC and check the wiring now. I hope someone has some idea.
PudSP1 is offline
Old 06-06-2009, 8:13 AM
Wires that are tight at a distance next to the frame may resonate sound and vibration and either break or strip their insulation.
One may be linking a sensor and while it is sending a 0.3V signal back it is grounding somewhere and throwing the ECU off. So I would back trace all the various sensors and their wiring.
I hear more Sp1s having problems than Sp2s though, is this a correct observation?
zerogara is offline
Old 06-06-2009, 8:35 AM
Bike(s): '02 Fireblade 954 , '99 SV650S
Rep: ridelikeaturtle is on a distinguished road (17)
Just curious, is the charging system working correctly?
ridelikeaturtle is offline
View ridelikeaturtle's Profile View ridelikeaturtle's Gallery Find More Posts by ridelikeaturtle
Old 06-06-2009, 3:53 PM
Not sure how to check this, I will take the bike to an auto electrician to get the battery and charging system checked when I get my next day off.
PudSP1 is offline
Old 06-06-2009, 4:04 PM
Check a Haynes manual for specifics for your bike, but basically put a multimeter (measuring DC volts) across the battery terminals while the bike is running w/the lights on at @4000 rpm. It should read @13.5-15.5v; this will tell you the alternator is charging the battery, and the voltage regulator/rectifier is metering that voltage output in the correct range.
I was just thinking if the voltage reg/rect isn't working (not uncommon for this to go on bikes), then the bike is running off the battery and when that drains after a few miles things electrical start running amok.
In your case it sounds more like a short somewhere, but I'd eliminate this first. You'll probably need a multimeter if you're going to track that down, so for the tenner it'll cost you (along w/a Haynes manual!), it's well worth it.
Good luck!
Old 06-06-2009, 7:12 PM
Yeah, I already have a multimeter and a workshop manual so I'll check it today. Also gonna check the earths on the battery and the frame/engine. Thanks for the reply.
PudSP1 is offline
Old 08-14-2009, 10:11 PM
Well.....I had the battery checked, it's ok. Checked all wiring, can't see any problems there either. Disconnected the PC3, over short rides it seems ok for the breaking down fault but it still has a huge hiccup when stopping and letting it idle (like at the lights) almost dies. Smells rich as hell when stopped. Gonna reconnect the PC3 and spray all connections with contact enhancer.
PudSP1 is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 7:45 AM.
