Wont run while on sidestand
Old 06-05-2009, 9:20 AM
Bike(s): 2007 CBR1000RR,2004 RC51 Nicky Hayden Edition
Rep: Bigtoe is on a distinguished road (34)
I am looking at an 04. The bike will not start while on its sidestand. Crazy. I dont remember my 01 doing that. Possible problems? Bike is clean and never been down. Bike rode like a dream. But when I stopped to take some pics (while on a test ride) I put the sidestand down and it kept running. As soon as I leaned it over and the sidestand had weight on it, it quits running. The guy that has it for sale knows of the problem and says he has no clue. He is a motorcycle enthusiast, so he know about bikes.
Thanks for any input
Marc
Bigtoe is offline
View Bigtoe's Profile View Bigtoe's Gallery Find More Posts by Bigtoe
Old 06-05-2009, 9:39 AM
Jetpilot07's Avatar
Rep: Jetpilot07 is a splendid one to beholdJetpilot07 is a splendid one to beholdJetpilot07 is a splendid one to beholdJetpilot07 is a splendid one to beholdJetpilot07 is a splendid one to beholdJetpilot07 is a splendid one to behold (691)
Re: Wont run while on sidestand
bad sidestand switch, when you lean it over to the sidestand and you put pressure on it, it's possibley grounding out on the frame stem
GENERAL ROBERT E. LEE
Jetpilot07 is offline
Old 06-05-2009, 9:42 AM
I can check that.
I forgot to mention that the fuel pump does not prime while sitting on the sidestand either. But when bike is stood up, it primes and will fire. Even with the sidestand down.
Thank you for your help.
I will check that and replace it.
Bigtoe is offline
Old 06-05-2009, 9:47 AM
Jetpilot07's Avatar
no problem, good luck.....get the part from cheapcycleparts.com
Old 06-05-2009, 1:18 PM
Bike(s): 00' cbr929rr
Rep: BigBassTurd is a glorious beacon of lightBigBassTurd is a glorious beacon of lightBigBassTurd is a glorious beacon of lightBigBassTurd is a glorious beacon of lightBigBassTurd is a glorious beacon of lightBigBassTurd is a glorious beacon of light (503)
Bad tip sensor? Try leaning it over with the kickstand up and see if it cuts out.
BigBassTurd is offline
View BigBassTurd's Profile View BigBassTurd's Gallery Find More Posts by BigBassTurd My Map Location
Old 06-08-2009, 10:18 AM
Jetpilot07's Avatar
i thought the same thing BBT, but he didn't say it was cutting off in hard leans while riding....
Old 06-12-2009, 9:51 AM
ghbzorro's Avatar
Bike(s): '88 Hawk GT; '98 Blade (for sale in Abu Dhabi)
Rep: ghbzorro is a jewel in the roughghbzorro is a jewel in the roughghbzorro is a jewel in the rough (260)
Hard leans while riding have essentially no effect on the sensor. It's when you lean over when NOT riding that it functions.
So I think that leaning over with the kickstand up would be a good test.
ghbzorro is offline
Old 06-12-2009, 10:42 AM
Delboy
fighter954rr's Avatar
Bike(s): Pedal Power!
Rep: fighter954rr has a brilliant futurefighter954rr has a brilliant futurefighter954rr has a brilliant futurefighter954rr has a brilliant futurefighter954rr has a brilliant futurefighter954rr has a brilliant futurefighter954rr has a brilliant futurefighter954rr has a brilliant futurefighter954rr has a brilliant futurefighter954rr has a brilliant futurefighter954rr has a brilliant future (1702)
Originally Posted by Bigtoe View Post
I can check that.
sounds like maybe a dodgy connection/loose angle sensor maybe? or the stand switch like jet says...
On a ban...
fighter954rr is offline
View fighter954rr's Profile View fighter954rr's Gallery Find More Posts by fighter954rr
Old 06-12-2009, 10:43 AM
Delboy
oh.... shoulda read all the posts... sorry guys!
On a ban...
Old 06-12-2009, 1:32 PM
Well...
sheepofblue's Avatar
Rep: sheepofblue has a brilliant futuresheepofblue has a brilliant futuresheepofblue has a brilliant futuresheepofblue has a brilliant futuresheepofblue has a brilliant futuresheepofblue has a brilliant futuresheepofblue has a brilliant futuresheepofblue has a brilliant futuresheepofblue has a brilliant futuresheepofblue has a brilliant futuresheepofblue has a brilliant future (1751)
There is a plug on the underside of you clutch lever (near the pivot) that has come loose. At least mine acted like that.
sheepofblue is offline
Old 06-18-2009, 11:07 AM
Ok. I got the RC. I felt the wires from the sidestand switch and the are broken where they round the frame. So I will order a new switch. Thanks everyone!
Bigtoe is offline
Old 06-18-2009, 3:04 PM
Jetpilot07's Avatar
Old 06-24-2009, 8:40 AM
Ok. Went to put switch on last night! Fackin bike did the same thing. LOL. So my wife and I started lookin at the PCIII and its connections to see if there was a chaffed wire. That was fine. Then I noticed the lean angle sensor (I'm guessing) was only bolted on with one bolt. So I put it back where it should be turned key and it primed every time. So I bolted it down. PROBLEM FIXED
Thank you all for your help and suggestions!
Bigtoe is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 11:50 PM.
