06-29-2009, 4:38 PM
Bike(s): 2005 RC51, CBR 1000RR Posts: 18
| Torque specs Does anyone know the torque specs for the oil pan and side engine cover bolts? |
06-29-2009, 4:49 PM
#2 | | choices we make define who we are
Join Date: 01-08-2009 Location: Haughton, Louisiana enroute to Iraq.
Bike(s): 2007 CBR1000RR Age: 35 Posts: 1,561
| Re: Torque specs the 8mm side cover bolts should be 28inch lbs, and the 10 mm pan bolts should be 14ft lbs, but i may be wrong, you need a manual!!!!!
__________________ DO YOUR DUTY IN ALL THINGS, YOU CANNOT DO MORE, YOU SHOULD NEVER WISH TO DO LESS! GENERAL ROBERT E. LEE |
07-01-2009, 6:59 AM
Bike(s): RC51 SP2 '02 RG500Γ Beta Zero Gara 260 Age: 45 Posts: 309
Rep:  (43) Rep Power: 3
| Re: Torque specs 28 in-lb sounds a little extreme to me for an 8mm bolt
That is about 336ft-lb which means 2 170lb guys sitting on top of 1ft wrench and jumping up and down  |
07-01-2009, 7:03 AM
Join Date: 09-07-2007 Location: Currently in Guelph, Ontario, Canada
Bike(s): '88 Hawk GT; '98 Blade (for sale in Abu Dhabi) Age: 57 Posts: 1,232
| Re: Torque specs Quote:
Originally Posted by zerogara 28 in-lb sounds a little extreme to me for an 8mm bolt
That is about 336ft-lb which means 2 170lb guys sitting on top of 1ft wrench and jumping up and down  | Umm, nope, it is 2.33 ft-lb |
07-01-2009, 10:21 PM
Bike(s): 2002 RC51 Posts: 52
Rep:  (18) Rep Power: 1
| Re: Torque specs Per the service manual:
(the engine side covers and oil pan bolts are 6mm flanged hex)
6mm flange bolt (8mm head, small flange) 7 Ft/Lbs or 84 In/Lbs. (10 Nm)
6mm flange bolt (8mm head, large flange) 9 Ft/Lbs or 108 In/Lbs. (12 Nm) |
07-13-2009, 1:12 PM
Bike(s): CBR929´00 Posts: 207
Rep:  (46) Rep Power: 4
| Re: Torque specs Unless you have a very good and precise torque tool, I suggest tightening them by hand.. I learned it the hard way.. |
07-18-2009, 10:32 AM
Originally Posted by ghbzorro Umm, nope, it is 2.33 ft-lb | You are absolutely right, I don't know what I was thinking at the moment.
in-lb in my experience are rarely found as specs and it is usually on stuff that I just go by the feel of the hand. Haven't had anything gone loose in 20 years or stripped. |
