05 battery dying
Old 08-03-2009, 8:15 PM
Bike(s): 05 RC51, 69' Mustang Mach 1 restomod
Rep: skwyd is on a distinguished road (24)
Send a message via MSN to skwyd
05 battery dying
I have a problem with my 05 and I need all of your expertise plz.
I recently replaced my battery after it died on me and figured that due to my colder climate in the winter (Utah) and it being 4 years old it was due. Today after taking my 3rd ride with the new battery, I found the battery was unable to start my bike again. I bump started it, and got it almost home but then my FI light started to flash and then it just died.
I did recently replace the "Hot boddies" crappy tail lights with new Ultra LED tail lights if anyone has had any issues with that aspect.
Any ideas would be appreciated from the brotherhood of the RVT.
skwyd is offline
View skwyd's Profile View skwyd's Gallery Find More Posts by skwyd My Map Location
Old 08-03-2009, 8:22 PM
Out Of Many, We Are One
Twincam's Avatar
Re: 05 battery dying
Try measuring the voltage across the battery when it is off/idling/reving about 4k... Just wondering whether your stator has gone
What batteries are you using?
Twincam is offline
Old 08-03-2009, 10:55 PM
Or rectifier/regulator (much cheaper problem). With a little charging the battery should show 12-12.5 easily. You need a slow charger to charge a battery well and most new batteries need to be fully charged before thay are put to work.
Once started the voltage should jump to 13.5+ and should climb a little more after revving it. If after starting it the voltage remains low or lower your charging system is down. The stator produces AC sends it the rectifier/regulator which converts it to DC and the regulator stabilizes the voltage depending on the needs, lights, charging, etc.
Is there a chance you pulled a connector or cut a wire while installing the undertail? The rect/reg part is metal with colling fins on it I believe on the left side of the subframe.
zerogara is offline
Old 08-03-2009, 11:54 PM
Thank you both for your insights. I will check both and get back with you tomorrow. THANKS!
skwyd is offline
Old 08-04-2009, 8:33 AM
Twincam's Avatar
Btw hows your Mustang? I keep saying if I ever won the lottery I would take her off your hands *drools*
Twincam is offline
Old 08-04-2009, 9:02 AM
well I havent sold her. I still need to get the dash all connected up, and then get her registered. I still think i would be willing to trade her for an original RC30 and some cash but.... Which is your favorite of all of your bikes by the way? my first bike was an 86 VFR and they have always held a special place in my heart.
skwyd is offline
Old 08-04-2009, 9:34 AM
Definition of a car: A vehicle to be used for transporting motorcycle parts back and forth that can;t be carried by your second motorcycle, or one that can drag a motorcycle trailer. A cage on wheels. Cats are never happy in cages, rats and hamsters are!
Which reminds me I haven't started my station wagon or my MK1 Cortina in 4,5 months!
zerogara is offline
Old 08-04-2009, 12:50 PM
Bike(s): Honda CBR 929rr
Rep: Tsunami40 is on a distinguished road (10)
Hi,
My 2000 929 went dead while riding last week as well:
Question: What is the "ground" when checking the stator wire and regulator/rectifier wire according to the service manual?
How do I know if it is the regulator/rectifier or the stator that needs to be replaced? Battery seems to be OK.
Background:
I can ride my bike for about 40 miles, then the battery will die while I'm riding if the bike idles while I'm riding, say at a toll booth.
When not riding I keep my bike on a battery tender.
I have the service manual and am following the instructions for the charging system troubeshoot:
Battery voltage is 12.5v
There is a 1.0 mA current leak.
Engine rev to 5,000rpm does increase voltage to about 14 with high beams on.
Can't figure out where the problem is with my multimeter.
I've been searching the forum and have read most threads pertaining to this topic. Just can't figure out which component it might be, reg/rec or stator?
Tsunami40 is offline
View Tsunami40's Profile View Tsunami40's Gallery Find More Posts by Tsunami40
Old 08-05-2009, 9:31 AM
Check your connections on the reg/rect and whether it is loose.
If you are getting voltage with all lights on above 12.5 that means it is charging. But it may not be doing it full time. Maybe your tender connector is shorting somewhere.....? If there is a way you can connect your voltage meter and tape it to the tank and go for a ride on an open no traffic oad and see what it does.
Also a dead battery will/might not charge sufficiently with a tender, and if the bike is dying it means it is dead dead, or there is a different problem.
When it dies, do you have to jump start it with an other battery?
It is easy to replace the reg/rect but hard or impossible to change the stator without proper tools (proper extractor at least).
The testing of the stator is according to manual, you measure the resistance of the coils. If you have a friend with a Honda with similar rect/reg ask him if you can switch it around.
zerogara is offline
Old 09-17-2009, 5:27 PM
Zerogara:
Thanks for the insight. It was my battery tender that was the source of the battery drain. I've since disconnected it.
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 5:55 AM.
