change water in radiator
Old 08-09-2009, 3:10 PM
Bike(s): 2004 rc 51
Rep: tj.lolley is on a distinguished road (10)
how do you change water in a 04 rc 51
tj.lolley is offline
View tj.lolley's Profile View tj.lolley's Gallery Find More Posts by tj.lolley
Old 08-09-2009, 3:16 PM
cbr1kfireblade's Avatar
Bike(s): CBR1000rr6
Re: change water in radiator
i just pulled the lower radiator hose off the water pump on my cbr
cbr1kfireblade is online now
Old 08-09-2009, 4:01 PM
Out Of Many, We Are One
Twincam's Avatar
Have you a workshop manual at hand? It would probably tell you in there
Btw, welcome
Twincam is offline
Old 08-09-2009, 10:02 PM
Long Live Chesty Puller
jrivas's Avatar
Bike(s): 2002 HONDA RC 51
Rep: jrivas is a splendid one to beholdjrivas is a splendid one to beholdjrivas is a splendid one to beholdjrivas is a splendid one to beholdjrivas is a splendid one to beholdjrivas is a splendid one to beholdjrivas is a splendid one to behold (827)
i have a manual for an 02 rc, but i would think its the same concept..... its actually says exactly what cbr1kfirblade said, which is to pull the lower hose of your water pump and let drain, just loosen the hose band screw and it should come right of, dont forget to remove what is in your reserve tank also as that stuff may be pretty nasty in there also (big no no)
"So they've got us surrounded, good! Those b*****ds won't get away this time!"
CHESTY PULLER, USMC
jrivas is offline
View jrivas's Profile View jrivas's Gallery Find More Posts by jrivas
Old 08-10-2009, 6:00 AM
What is a safe mix to use to flush out the system? I have used a tiny bit of dish-washing machine liquid soap (non foaming soap) and salt remover in cars and flush it out a few times after bringing it to a temp. high enough to open the thermostat, therefore circulating around the radiator. Most of the bikes I have done seemed pretty clean so I used plenty of tap water.
The detergent must have worked great as crap would come out that wouldn't with just water.
zerogara is offline
Old 08-10-2009, 10:36 AM
jrivas's Avatar
zerogara, that is a trick you had rolled up your sleeve eh this is the beauty of fireblades.org, hey tj, mr zero i think just topped it off with his relpy. good stuff zero
CHESTY PULLER, USMC
jrivas is offline
Old 08-10-2009, 5:01 PM
Bike(s): rc51
Rep: kewjr is an unknown quantity at this point (9)
just flush with distilled water until all the old coolant is out. works well for mebeen doing it for years. i also run it with the distilled water to heat the water up and dissolve more of the crap in cooling system. when distilled water comes out clear, im done flush.
kewjr is offline
View kewjr's Profile View kewjr's Gallery Find More Posts by kewjr
Old 08-10-2009, 5:09 PM
WYSIWYG
macca9540's Avatar
Bike(s): 2003 954 fireblade
Rep: macca9540 has a reputation beyond reputemacca9540 has a reputation beyond reputemacca9540 has a reputation beyond reputemacca9540 has a reputation beyond reputemacca9540 has a reputation beyond reputemacca9540 has a reputation beyond reputemacca9540 has a reputation beyond reputemacca9540 has a reputation beyond reputemacca9540 has a reputation beyond reputemacca9540 has a reputation beyond reputemacca9540 has a reputation beyond repute (2822)
Also, on my 954 this is, the radiator inlet and outlet are in the middle of the radiator so it won't drain completly. So I got some clear tube and syphoned it before I flushed it with fresh water. I also undid as many hoses at their lowest point to get all of the old coolant out before flushing.
macca9540 is offline
View macca9540's Profile View macca9540's Gallery Find More Posts by macca9540 My Map Location
Old 08-10-2009, 5:34 PM
Red Rider's Avatar
Bike(s): '01 CBR929
Rep: Red Rider has much to be proud ofRed Rider has much to be proud ofRed Rider has much to be proud ofRed Rider has much to be proud ofRed Rider has much to be proud ofRed Rider has much to be proud ofRed Rider has much to be proud ofRed Rider has much to be proud of (1091)
On a 929/954, you should remove the drain plugs on the water pump and block to make sure you get it all out...
Red Rider is offline
Old 08-10-2009, 5:39 PM
WYSIWYG
macca9540's Avatar
Now you tell me. Where were you when I put up my thread about it.
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 10:57 PM.
