Need help cant torque front axel to spec???
Old 09-08-2009, 12:19 AM
Bike(s): 00 RC-51, UNDERTAIL W/INTERGRATED LIGHTS, JARDINE
Rep: RC-51 is on a distinguished road (10)
Not sure what the deal is but I swaped front tires and cant get axel to tighten without tightening up the bearings.
The wheel won't free spin till I almost back all pressure off axel bolt.
I didn't realize it at first and threw wheel on in a hurry and didn't notice it and went riding.
Rode ten miles and one bearing went out that I replaced last year.
The brakes are hanging up also. Will not roll free.
Took it apart and can't tell what's wrong.
Something bent or worn???
NEED HELP. PLEASE HELP. I AM NERVOUS FOR MY SAFETY. THANKS Guys
RC-51 is offline
View RC-51's Profile View RC-51's Gallery Find More Posts by RC-51
Old 09-08-2009, 11:33 AM
Red Rider's Avatar
Bike(s): '01 CBR929
Rep: Red Rider has much to be proud ofRed Rider has much to be proud ofRed Rider has much to be proud ofRed Rider has much to be proud ofRed Rider has much to be proud ofRed Rider has much to be proud ofRed Rider has much to be proud ofRed Rider has much to be proud of (1091)
Re: Need help cant torque front axel to spec???
Did you install the spacers correctly? Not familiar with the RC51 set up, but I'm guessing you maybe installed them on the wrong sides...
Red Rider is offline
Old 09-08-2009, 12:06 PM
Bike(s): 2005 RC51
Rep: Diamondback is on a distinguished road (14)
Likely he is missing one. If they were swapped, the rotors would not line up in the calipers. Get a service manual or download one. The spacers are referred to as "collars" in the manual. Good Luck!
Diamondback is offline
View Diamondback's Profile View Diamondback's Gallery Find More Posts by Diamondback
Old 09-08-2009, 2:42 PM
That is exactly what the spacers do, allow the axle to be tight without putting any pressure on the outer races.
Also if your pads drag it could be because they can't self adjust to that far of a displacement of the disks, so the problem must be related.
A friend recently with an older bike and speedo drive installed everything backwards as the tire was installed backwards. On his bike it worked, although the needle would stick below 0 mph and the odometer would take miles off
zerogara is offline
Old 09-08-2009, 6:28 PM
Bike(s): '00 RC51
Rep: longwaytofall is on a distinguished road (10)
Did you put the spacer in the wheel that goes between the bearings? If that is out and you are cranking down on it, those bearings are going to be pissed.
longwaytofall is offline
View longwaytofall's Profile View longwaytofall's Gallery Find More Posts by longwaytofall
Old 09-09-2009, 10:04 AM
KDA
Bike(s): '03 KTM525SX '03 RC51
Rep: KDA is on a distinguished road (20)
The spacers are definitely two different sizes. Must have the correct one on each side.
KDA is offline
View KDA's Profile View KDA's Gallery Find More Posts by KDA
Old 09-09-2009, 7:22 PM
Bike(s): Honda varadero/SP1 Hybrid (Varastorm)
Rep: pbc0 is on a distinguished road (12)
Sounds to me like you're missing the distance collar that fits inside the wheel between the bearings. Easy to forget about when you're changing the bearings. If this was done by a lazy arse then they can hide it by tightening up the wheel spindle finger tight, tightening up the fork collars then finally tightening the spindle bolt. All's well till the bearings **** up own the road.
pbc0 is offline
View pbc0's Profile View pbc0's Gallery Find More Posts by pbc0
Old 09-09-2009, 8:35 PM
Bike(s): 2003 CBR 954RR
Rep: Wheeliest is on a distinguished road (31)
normally when you burn up a bearing it damages the inner spacer between the bearings... inspect that inner spacer for damage and you need to learn to seat the axle, next time don't tighten the axle down and don't tighten the pinch bolts down but firmly tighten the axle with a wrench or socket, then push your bike forward and stab the front brake a few times and that will seat your axle.. then tighten the pinch bolts on the end of the axle that the end bolt does not go into.. then tighten the axle to spec then pinch bolts.
Wheeliest is offline
View Wheeliest's Profile View Wheeliest's Gallery Find More Posts by Wheeliest
Old 09-09-2009, 9:38 PM
This sounds the closest if you ask me. However I will look into all but may start here. I backed off axel bolt till wheel would spin freely and then tightened pinch bolts on forks. The brakes are always hissing and hanging up and also have roll resistance. I will double check wheels spacers being I bought the Honda service manual yesterday. I had service Techs check it when they swapped tire but didn't know what to tell me. So I figured if you want the job done right gotta do it yourself. I hav had several service techs hands in there and always keep having problems. SO I WANT TO FIND ROOT OF ALL EVIL!!!!What keeps bringing on these consistant problems etc. May check and grease calipers etc. Thanks so much for all your help and sorry for the book. Lol
RC-51 is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 4:27 AM.
