| Re: Gonna build the motor I'd look for HRC heads and pistons and use SP2 injection which is by far superior.
I don't think the bottom has much of a difference, the clutch I remember having some differences.
Reboring and replating is a major job, I think you can find a whole SP2 motor on eBay for less (problems & cost). I've seen them go for less than some late 600s. The Honda plating is a very unique compared to most others, which doesn't mean you can;t try a different process (look up LA Sleeve among others).
I don't think you want to try to go to a larger bore, not that you have much metal there to do so, but the motor is already oversquare. If you compare the MX 450s they range 95-97mm while the rc is at 100mm with shorter stroke. I'd research the possibility of leaving the bore alone and see if you can go 2mm up on stroke, which due to the design you must utilize equally/2 shorter rods, therefore higher piston speeds at equal rpm. But a longer stroke will give you a little more usable power with a bit off top end cut off, which the motor is already capable off but for safety and longevity is restricted.
As someone else on an other thread had pointed out to me as well, the stock pistons are 10.8 while the HRC are 12.8:1, but 0.3 comes from the heads having smaller squish volume than the stock head, so HRC pistons alone will only bring it up to 12.5. The port design on the SP2 is a bit better than the SP1 (O vs D).
If your bores are not scuffed I'd leave them alone. There are other aftermarket pistons you can use, I think Wossner makes them and are as good as gold.
RC51 100mm x 63.6mm 10.8:1
ktm 525 95 x 72 mm
'10 CR450 96mm x 62.1mm
Ducati
96 999S 100 x 63.5 mm 11.4:1
96 999R 104 x 58.8 mm 12.5:1
1,099 cc 104 mm x 64.7 mm 12.5:1
1,198.4 cc 106 mm x 67.9 mm 12.8:1
KTM RC8 1,148 cc bore/stroke: 103 mm x 69 mm
