| Re: Newbie - RC51 Running rough and backfiring Left and right exhaust, meaning left and right can? They both come out of the same place, you should only be comparing heat from head pipes. If what you say is true one of them may be plugged up with something. Maybe someone played a joke on you and shoved something down the muffler. Or maybe water has collected at the bottom but that would be thrown off after a good long ride.
Once cold when you start it up idling check if front to back head pipes get warm equally and at the same rate. If you plug up one muffler the bike will still run as all gases are forced to the one exit. One guy here bought a bike with stock head pipes and one aftermarket muffler with the left side lugged at the exit. A cheap way to lighten up the bike. |
