sp2 speedo cluster
Old 10-31-2009, 3:32 AM
Bike(s): honda sp2 2005
Rep: ppereira is on a distinguished road (10)
sp2 speedo cluster
Hey Guys
Has anyone had parts of the digital display on the speedo and temperature drop out.This will go on for a couple of days and then comes good for a while and thens happens again.Any ideas?
ppereira is offline
View ppereira's Profile View ppereira's Gallery Find More Posts by ppereira
Old 10-31-2009, 6:17 AM
Re: sp2 speedo cluster
Vibrations tend to shake electrical connections loose on the RC, even cut wires in some bikes, check your connections. It must be all be fed through the ECU on the SP2 but you may also want to check the connection on the temp sensor that feeds into the ECU which is critical to how the bike runs or turning the fans on if it overheats. I doubt it is the cluster itself, it must be wiring related. Search and read all threads with wiring problems.
zerogara is offline
Old 11-11-2009, 10:17 AM
Bike(s): 2001 RC51
Rep: slammp is on a distinguished road (10)
I had this same problem. Took off the front fairing, disconnected the digital display and cleaned up the connections. Reconnected and everything is good.
slammp is offline
View slammp's Profile View slammp's Gallery Find More Posts by slammp
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 9:16 AM.
