Showa front fork problem - Honda Motorcycles - FireBlades.org
Honda RC51 Discussion of the Honda RC51, Honda SP1, and Honda SP2 Motorcycles.
post #1 of 9 Old 03-26-2012, 12:45 AM Thread Starter
Reputation Power: 12
Brought the grand old lady to the Shanghai F-1 track yesterday, and she enjoyed it all over ... one problem though, with the front fork (all standard, 2002 SP-2).
It seems the forks bottoms out some 4 cm (1.5 inch) above the end of the travel.
I already noticed this during some test rides, but even on the track at hard braking it does not change.
I initially thought the oil level was too high and thick, and changed it out for new one.
Problem persists however.
Oil 10W, 498cc each leg
Pre-load: 10 turns clockwise
Rebound: 1 1/2 turn from full closed
Compression: 16 clicks from full closed
I am around 100kg full dressed
ericjansen is offline
post #2 of 9 Old 03-26-2012, 4:33 AM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Re: Showa front fork problem
If you undo the fork cap and compress the fork it compresses 40mm further than it does while riding?
You set the oil level to 135mm as specified?
post #3 of 9 Old 03-26-2012, 4:44 AM Thread Starter
1. Yes, with fork caps off, its got full travel.
2. I did not disassemble the forks, but I left the forks 2 days upside down with regular pumping. I am pretty sure the legs were empty of old oil.
I filled up with 498cc each leg, but did not measure the level (as this is measured with springs out, right)?
I am pretty sure the volume I inserted is close to the 498cc required.
I hear what you say though, The problem looks like air-gap related.
The strange thing is that exactly the same happened with old and new oil.
post #4 of 9 Old 03-26-2012, 4:51 AM
Images: 2
Quoted: 2 Post(s)
So you only have 80mm of travel of the full 120mm?
Maybe whoever changed the fork oil last time did it the same way instead of setting the air gap? The oil volume is irrelevant - the air gap is what matters.
post #5 of 9 Old 03-26-2012, 10:11 AM Thread Starter
You are absolutely right. I just opened up the forks and they definitely had too much oil in it. Set them at the correct level, added a titsy pitsy to be sure they will not bottom out, and just installed everything back.
Will not be able to ride before the weekend, but even from pushing by hand it feels different, so I guess it is solved.
Thanks for the advise!
Good to know there were no other hidden defaults in the fork.
post #6 of 9 Old 03-31-2012, 4:04 PM
Reputation Power: 9
Dont forget the SP2 has a long topout spring, so theres about 20+mm of lost travel.
mondo is offline
post #7 of 9 Old 03-31-2012, 6:11 PM Thread Starter
Yeah, learned that.
I thought to take a shortcut by not removing the springs, just add the oil by volume. As always, shortcuts don't work.
The fork is working fine now, using it's full travel minus the last 5 mm at softest setting.
Thanks for all advise!
post #8 of 9 Old 04-01-2012, 1:43 AM
Reputation Power: 9
Yeah, learned that.
I dont mean the compression spring, the topout spring is inside the valve tube, if you pull on the forks you will see how much travel they take off.
mondo is offline
post #9 of 9 Old 04-01-2012, 4:24 AM Thread Starter
Yes, i know, but that can only be solved with a re-built, which I do not want to do right now.
What I missed was the lower 4cm of travel.
Altogether, the topout problem, plus bottom problem left not much suspension left. But as said, all fixed.
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda RC51
Human Verification
Search tags for this page
bikes using showa 41' front suspension
fork oil capacity problem
harley davidson showa front forks
rc51 fork travel
showa forks
showa forks cbr 600
showa front forks
showa motorcycle forks
too much oil in front forks
volume oli shock ninja 150
Front fork problem drooger Honda FireBlade 6 04-05-2009 8:46 PM
SP1 Showa fork help needed. Stephenrc45 Honda RC51 2 11-24-2007 10:44 AM
F4i Front Fork Vibration Problem TheJackal Honda CBR 600 8 06-25-2007 9:24 PM
Fork Problem Mark024 Honda FireBlade 2 03-29-2004 10:37 AM
front fork sag problem DavidGS Honda FireBlade 4 10-03-2003 8:47 PM
