Go Back   Honda Motorcycles - FireBlades.org Forums > Articles > How To Articles
How To Articles: Specific how to do stuff articles.
Dewinterizing tips
Old 02-15-2009, 2:42 AM
lanbrown's Avatar
Rep: lanbrown is a jewel in the roughlanbrown is a jewel in the roughlanbrown is a jewel in the rough (268)
Dewinterizing tips
For some it is starting to warm up, others it never really got cold and then the last group; well sorry, it’s still cold.
When it is time to ride, what do you need to do? The battery should be fully charged; the air pressure in the tires should be checked. The fuel should be good, as fuel stabilizer should have been added before it was stored and the oil should have been changed. A thorough check of the bike should also be performed; check the brakes and the clutch. Check the major nuts and bolts to make sure they are tight, check the chain slack and lube it as well. Let the bike fully warm up, check for any leaks and then hit the road and have fun.
lanbrown is offline
Old 02-15-2009, 6:49 AM
Out Of Many, We Are One
Twincam's Avatar
Re: Dewinterizing tips
A good set of instructions there Lan!
NB: If you did not add fuel stabilizer to the fuel system, the fuel may have gone stale and "off". As a result, it will not ignite as easy and therefore may give you problems starting/idling and also generally running.
Drain the tank and add a fresh supply.
Twincam is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 9:23 PM.
