Originally Posted by DingDongGo What kind are the signal leds? Or how can I find out? |
It can be rather tricky to determine the voltage and current of the led since it blinks. It's a 5mm led and I would assume it would either be 3.0V or 5.0V and around 30mA. You might have to buy a couple of each and give them a try. I would think it would be 5.0V 30mA but that is only a guess.
Method #1: You could use a multimeter and try to determine the voltage but you would need an expensive one that senses changes very quickly. Just touch one lead to one side of the led and the other lead to the other side of the led. You will probably have to do this on the back of the board while it is plugged in an functional. You can also try to determine the current by breaking the circuit. De-solder one led and set the multimeter to read current then touch each lead to each connection on the board. This method probably will probably lead to poor results.
Method #2: I determined the voltage and current of the backlight led's by taking one off the board and putting a known current through it with a power supply and resistors. I increased the current bit by bit until it lit up properly. I then increased the current until it blew up and took this as an absolute maximum. The proper current for a led is more important than proper voltage.
Hope that made some sort of sense.
Petropolis
