How To Articles: Specific how to do stuff articles.
Quickly make front wheel stand for storage
10-03-2009, 11:09 PM
Bike(s): 2001 Honda CBR929RR Posts: 12
Rep:  (45) Rep Power: 0
| Quickly make front wheel stand for storage Here is a quick front wheel stand I made for storage of my bike. It is made out a piece of 3/8" plywood as a base and then I used some 2x3's (could use 2x4's) that I had laying around for the supports. Make sure you use some good quality outdoor wood glue between the joints and some decent length screws (I used 2.3" deck screws). I liberally applied some glue to the outside of the joint that I had laying around because it was getting old.
The whole stand took me about 15 minutes to make. It doesn't look like much but it serves it's purpose. It is very stable when the bike is on it. It is a little tricky to put under the front forks but if you lift the bike from the top of the front rim and get a buddy to slide the stand under it works well.
This stand could also be used to remove the front wheel. If this is the intent make sure that there is enough space under the front tire and the base of the stand when it is on the stand so you can get the tire out from under the front fender.
Petropolis |
10-04-2009, 1:35 AM
Bike(s): CBR929, 3xGSXR750, GSXR1000, ZX6R, XS250, KZ750 Age: 43 Posts: 9,528
| Re: Quickly make front wheel stand for storage Quote:
Originally Posted by Petropolis Here is a quick front wheel stand I made for storage of my bike. It is made out a piece of 3/8" plywood as a base and then I used some 2x3's (could use 2x4's) that I had laying around for the supports. Make sure you use some good quality outdoor wood glue between the joints and some decent length screws (I used 2.3" deck screws). I liberally applied some glue to the outside of the joint that I had laying around because it was getting old.
Petropolis | Very cool indeed :-)
I'm guessing by the flat edge that it is strong enough that you can lever the bike onto it normally rather than jacking the bike up and siding it under?
10-04-2009, 2:42 AM
Originally Posted by bladeracer Very cool indeed :-)
I'm guessing by the flat edge that it is strong enough that you an lever the bike onto it normally rather than jacking the bike up and siding it under? | I never tried that but I will have to. That is definitely a good idea. |
10-04-2009, 4:31 AM
#4 | | i like to ride all the time
Bike(s): cbr 929 2001 Posts: 319
Rep:  (14) Rep Power: 2
| Re: Quickly make front wheel stand for storage nice work good for the handy man and beats going to the shop for one :] |
10-04-2009, 5:09 AM
Bike(s): '98 Fireblade RRW, '88 VFR750 FJ Posts: 1,401
| Re: Quickly make front wheel stand for storage Nice bit of work there! |
10-04-2009, 7:49 AM
#6 | | Unleash the POWER!!
Bike(s): Cbr600F4 1999(sold)Repsol Blade 2007 Age: 5 Posts: 9,883
| Re: Quickly make front wheel stand for storage Like it  , wonder if the same could be done for the rear ????
The mind is a funny thing Jazzy's Blog |
10-04-2009, 7:31 PM
Originally Posted by jazzy Like it  , wonder if the same could be done for the rear ???? | The same type of stand would work for the rear but instead of putting the v-notches that the forks sit on all you need is a hole on each arm of the stand to stick a rod through the stand and hollow rear axle. I have a simple steel stand that I made that I will post soon. (This of course will only work if you have a hollow rear axle) |
10-05-2009, 12:14 AM
#8 | | WYSIWYG
Bike(s): 2003 954 fireblade Age: 53 Posts: 6,969
Petropolis |  Necessity is the mother of invention.
__________________ I was young and stupid then. I'm old and stupid now. We get too soon old, and too late smart. |
10-05-2009, 12:40 AM
Originally Posted by Petropolis The same type of stand would work for the rear but instead of putting the v-notches that the forks sit on all you need is a hole on each arm of the stand to stick a rod through the stand and hollow rear axle. I have a simple steel stand that I made that I will post soon. (This of course will only work if you have a hollow rear axle) | This works but has the drawback that you can't remove the wheel.
10-05-2009, 1:51 AM
Originally Posted by bladeracer This works but has the drawback that you can't remove the wheel. | That is a valid point but it does work well for tightening and waxing the chain and storing the bike for winter. |
10-05-2009, 11:10 AM
#11 | | Unleash the POWER!!
Originally Posted by bladeracer This works but has the drawback that you can't remove the wheel. | Quote:
Originally Posted by Petropolis That is a valid point but it does work well for tightening and waxing the chain and storing the bike for winter. |  also. Be good if you could fashion something quick,simple and easy enabling the removal of the wheel
10-05-2009, 11:18 AM
Originally Posted by jazzy | Same thing but put the rod through the swingarm pivot.
10-05-2009, 11:47 AM
#13 | | Unleash the POWER!!
Originally Posted by bladeracer Same thing but put the rod through the swingarm pivot. | Would'nt that be the same as a centre stand? Sorry could be me getting confused?
10-05-2009, 12:07 PM
#14 |
Originally Posted by jazzy Would'nt that be the same as a centre stand? Sorry could be me getting confused?  | Not sure what you mean Jazzy.
But yes, it supports the bike nearer the centre.
If you were removing both wheels, you'd probably have to remove the rear first to keep it balanced.
10-05-2009, 1:02 PM
#15 | | Unleash the POWER!!
If you were removing both wheels, you'd probably have to remove the rear first to keep it balanced. | Sorry as usual I didn't explain myself very clearly, just when you said to put a rod through the swingarm pivot, I thought...then looked at my swingarm and was just checking. There is a spot just behind that where you could support underneath the swingarm by placing strong piece of timber or covered strip of metal through in a similar fashion.
No that I've written this, the front is a good idea but I think a pre-fab'ed stand is better (easier) for the rear.
Thanks Larry, I'm getting there...honestly, just a little slow sometimes
10-05-2009, 2:39 PM
#16 |
Originally Posted by bladeracer Same thing but put the rod through the swingarm pivot. | Hmm, like a home-made Abba stand... good idea Bladeracer!  |
10-05-2009, 4:17 PM
#17 | | Unleash the POWER!!
