Go Back   Honda Motorcycles - FireBlades.org Forums > Other Motorcycle Brands > Kawasaki Motorcycles
Kawasaki Motorcycles: Discussion of Kawasaki Motorcycles.
Help I'm so close, see the video
Old 07-31-2007, 11:33 AM
Bike(s): 1990 ZX11-C1
Rep: FrankieZee is on a distinguished road (10)
Hi all, after 3 weeks of working on my new 1990 ZX11C with 6100 on the clock
Everything is stock except for the cam's but I have no way of confirming this.
I feel I'm very close to getting it running minty mint.
Here's what I've done so far.
Rust in the tank, Fixed Por-15, cured 96 hours.
Carbs rebuilt, new float valve, float valve seat/screen, float bowl gasket & o-rings.
Counted 3 turns in on the pilot screws and 3.5 on #3 carb.
2 cans of gumout, my carbs look almost new.
Checked fuel level in the bowls, all in Spec.
Checked for vacuum leaks, boots from the carbs to the heads are good.
Fresh set of nkg's double checked the gaps.
Ohm and gap tested the pickup coil, Ohms were good 380-570.
gap was at 0.5 should have been 0.7, she ran better after this adjustment.
Static tested the coils,
Both primary resistance were @ 3.0 Ohms and are in spec
Both secondary resistance were @ 23,000 +/- 1500 Ohms, should be 12,000-18,000
Checked the timing, left side coil good, right side coil out of time.
Hard to get a steady idle to know for sure.
Half fast synchronized the carbs, got them close.
I tried different adjustments on the pilot screws.
1 1.5 1.3/4 2 2.5 3.0 3.5
Took apart the IC ignitor, contacts were filthy.
I think that's about it.
Before the tear down of the carbs and tank coating
she was very hard to start and would not idle, I had to leave the choke
on 3/4 at the red lights, once I took off I could close the
choke and she would run like a raped ape or at least until the next red light.
Throttle response was boggy for the first second or two after that
I could red line all the way.
Now after all the above she starts with no problem but very boggy on the rev's
and I cant get her to rev even close to red line.
I don't know if you can see it in the video but when I do get her to rev
a fine mist of gas comes out threw the carbs.
I double check everything with the book when I did the carbs.
The plugs are new and only have about a hours time on them but they
look clean, not wet or black but good and clean.
Things I haven't done.
Valve clearance, I don't have the gut's to yank the valve cover off.
I have been looking online at different after market coils and timing modules.
That include a new module with several settings, 2 high output coils @ 3.0 Ohms
and a pick up coil and wire harness.
$400.00 for the module kit and $200.00 for the coils.
My one and only Kawi dealer quoted me $300-$600 for the valve adjustment.
I'm at end of my rope here guys and I have been scouring all the forums,
I've picked up a lot of good stuff but I don't know what to do next.
PLEASE ADVISE !!!
Frankie Zee...
Video of 90ZX11Bogging - Photobucket - Video and Image Hosting
FrankieZee is offline
View FrankieZee's Profile View FrankieZee's Gallery Find More Posts by FrankieZee
Old 07-31-2007, 9:59 PM
Re: Help I'm so close, see the video
24 views and not one reply
Old 08-01-2007, 12:44 PM
2-Up SISSY
slickwill's Avatar
Bike(s): 2002 CBR 600F4i / 2003 XR650R 'Tard
Rep: slickwill has a spectacular aura aboutslickwill has a spectacular aura about (196)
I made it view number 25 probably. I'm confused on what your actual question is?
slickwill is offline
Old 08-01-2007, 1:05 PM
Bike(s): '97 CBR 600R
Rep: loadedthorn is on a distinguished road (10)
Send a message via AIM to loadedthorn
I'm pretty sure that's the issue, but I have nothing of value to contribute.
loadedthorn is offline
View loadedthorn's Profile View loadedthorn's Gallery Find More Posts by loadedthorn My Map Location
Old 08-24-2007, 12:14 PM
Bike(s): 2001 CBR929RR
Rep: midas6t6 is on a distinguished road (10)
Since you think there are aftermarket cams installed, I'd check the cam timing and valve clearances to make sure they are ok. Synchronize the carbs correctly too.
midas6t6 is online now
View midas6t6's Profile View midas6t6's Gallery Find More Posts by midas6t6
Old 08-25-2007, 12:02 AM
Thanks for the heads up, I waiting for my g-friend to clean out her garage so I can adjust the valves there.
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 6:53 AM.
