Go Back   Honda Motorcycles - FireBlades.org Forums > Other Motorcycle Brands > Kawasaki Motorcycles
Kawasaki Motorcycles: Discussion of Kawasaki Motorcycles.
2008 Kawasaki Ninja ZX-14 - Photos And Specifications
Old 07-13-2008, 11:06 AM
I'm a bird.. NOT a bloke!!!
LoopyLee's Avatar
Bike(s): Honda, Kawasaki
Rep: LoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond repute (2620)
Send a message via MSN to LoopyLee Send a message via Skype™ to LoopyLee
Not content with sitting on their laurels after the launch of the 2006 ZX-14, the engineers at Kawasaki have fine tuned the engine and exhaust system of the ZX-14 to comply with newer the tougher EuroIII emissions and noise regulations, as well as making changes to the chassis and bodywork.
By reducing the internal mechanical engine noise, adding a third honeycomb catalyser to the collector, increasing the size of the cylinder heads secondary air ports, and making adjustments to the fuel injection system Kawasaki’s engineers have produced a bike with an improved engine, lower emissions and increased power across the range. The low end torque is greater, the bike has a smoother and stronger mid-range and the peak power is increased.
In addition to this the engineers also looked at the design of the chassis and by switching to die casting instead of gravity for the aluminium sections, they were able to reduce weight on their already compact and slim monocoque frame.
With its relaxed riding position, narrow engine and frame, low slim fronted seat riders may be forgiven for thinking they are on a sports tourer.. One twist of the throttle is all it takes to convince you otherwise..
Specifications
Engine: Four-stroke, DOHC, four valve per cylinder, inline-four
Displacement: 1,352cc
Bore x stroke: 84.0 x 61.0mm
Maximum torque: 154 N/m {15.7 kgf/m} 113.5 lb-ft @ 7,500 rpm
Compression ratio: 12.0:1
Fuel Injection: DFI with 44mm Mikuni throttle bodies (4)
Ignition: TCBI with Digital Advance
Cooling System: Liquid Cooled
Transmission: Six speed
Final drive: X-Ring chain
Front suspension: 43mm inverted cartridge fork with adjustable preload, 13-way compression and 11-way rebound damping adjustment / 4.6 in.
Rear suspension: Bottom-Link Uni-Trak® and gas-charged shock with adjustable preload, step-less rebound and compression damping adjustments, adjustable ride height / 4.8 in.
Front Brakes: Dual semi-floating 310 mm petal discs with dual radial-mounted four-piston callipers
Rear Brakes: Single 250mm petal disc with twin-piston calliper
Rake: 23 degrees
Trail: 94 mm
Front Tire: 120/70 ZR17
Rear Tire: 190/50 ZR17
Wheelbase: 57.5 in.
Overall length: 85.4 in.
Overall width: 29.9 in.
Overall height: 46.1 in.
Ground clearance: 4.9 in.
Seat height: 31.5 in.
Dry weight: 485 lbs.
Fuel capacity: 5.8 gal.
Colours: Metallic Midnight Sapphire Blue, Atomic Silver
Special Edition Colour: Metallic Flat Spark Black/Metallic Persimmon Red
ID:	30641  Click image for larger version
ID:	30648  Click image for larger version
ID:	30649  Click image for larger version
ID:	30651  Click image for larger version
Some days you're the bug; some days, the windscreen!
Blade Rider - Life, The Universe & Everything.. Biking
LoopyLee is offline
View LoopyLee's Profile View LoopyLee's Gallery Visit LoopyLee's homepage! Find More Posts by LoopyLee
Old 07-13-2008, 11:49 AM
Bike(s): 2006 CBR1000RR
Rep: HCCAFan is on a distinguished road (15)
Re: 2008 Kawasaki Ninja ZX-14 - Photos And Specifications
Looks crazy! How goes the Busa/ZX14 war these days anyway?
HCCAFan is offline
View HCCAFan's Profile View HCCAFan's Gallery Visit HCCAFan's homepage! Find More Posts by HCCAFan My Map Location
Old 07-13-2008, 11:52 AM
LoopyLee's Avatar
I luuuurve the look of the red and black one....
(and notice how I managed to get a photo of a girl riding one in )
LoopyLee is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 8:00 AM.
