The all new 2009 Honda CBF125 is quite simply an attractive proposition for new riders, and those looking for a round town commuter. Attractive, comfortable and convenient and offered at a price which definitely will not break the bank. PLUS Honda estimate that in these cash strapped times you may be able to get 134 miles to the gallon if you ride economically! A recent road test, although it must be said not riding economically, actually got 120 miles to a gallon of fuel! Wouldn’t we all love to have that kind of fuel economy from our bikes?
This bike is available to the European market from spring 2009, and is expected to become a best seller during 2009. Priced at or under the £2000 mark I doubt the expectations will be far wrong.
The bike, while compact, is still full of features. The fairing design was inspired by Honda’s large semi-faired and naked bikes and incorporates a half fairing and screen, which will offer some measure of protection against wind at speed. The upright riding position will give a reassuring amount of visibility, which is especially good for new riders in busy traffic. The lively fuel injected engine is nippy at low revs and smooth all the way up to the top of the rev range. Handling the bike is so effortless and it will get you around town with ease but still manage well out of town as well.
Steve Martindale, Honda UK's General Manager for motorcycles, says of the bike
"The addition of the CBF125 to Honda's range will be a great boost for the UK market with the 125cc sector continuing to grow. The CBF125 combines the best features of Honda's 125cc and naked models from over the years to provide a superb small motorcycle that doesn't compromise style or performance and is also very economical to run.”
Features
A single-cylinder, fuel-injected, air-cooled engine delivers sensational and 125cc Naked class-leading power (8.3kW) and torque (11Nm).
Compact engine configuration features a high lift cam for lighter weight.
Fuel-injection system’s long intake and connecting pipes provide an optimal airflow that contributes to quick pickup speed and fast acceleration away from the lights and ahead of city traffic.
Multi-map CDI system ensures power delivery is strong, linear and easy to manage throughout the performance range.
Easy-operation 5-gear shift lever gives light, smooth, easy and confidence-building control of the impressive power on tap.
Convenient push-button electric starter provides easy, reliable starting in all weathers.
Fuel-injected engine delivers well over 600km on one 13L tank.*
Fuel-injection system integrates Honda’s oxygen-sensing catalytic converter system, reducing exhaust emissions to well below the standards set by EURO-3 regulations while still maintaining the engine’s exhilarating performance.
*Honda figures obtained in test conditions.
Clear, easy to read instrument panel features a large speedometer and indicator lights, and a highly practical fuel gauge.
Instrument panel is set in a sporty carbon fibre-inspired background pattern that gives it a clean, functional appeal.
Large, brilliant multi-reflector headlights offer brilliant visibility and feature a unique design that accentuates the CBF125’s dynamic profile.
Compact fuel tank complements the sleek, muscular lines and features a Wing graphic that gives it an assertively sporty presence and declares the quality of its heritage.
Neat rear profile is sharply aerodynamic and features a specially designed tail-light and indicator array that’s unique to this motorcycle.
Wedge-shaped tail-light and bright clear lens indicators with amber bulb indicators offer high visibility as well as eye-catching style.
Specially conceived 17" Mat Axis Grey Metallic alloy wheels feature an elegant swept 6-spoke pattern that amplifies the CBF125’s ‘real motorcycle’ appeal, and have the practical advantages of being both robust and easy to clean.
Front wheel contour is accentuated by a sporty two-tone silver and black fender.
Unique rear hugger offers additional protection for the swingarm.
Attractively sporty-looking split seat offers a feeling of tailor-made comfort to riders and passengers of all proportions.
792mm seat height provides easy reach to the ground, even for younger or shorter riders, and creates a relaxed and confident ride feel.
Comfortable passenger seat is complemented by a sleek grab rail and folding aluminium foot pegs.
Air vents on side of seat accentuate the aerodynamic look as well as directing air flow to prevent heat building up on longer trips.
Colours include: Sports Red, Black and Space Silver Metallic.
Specifications
Engine Type: Air-cooled 4-stroke 2-valve OHC single
Engine Size: 124.7cm3
Bore & Stroke: 52.4 x 57.8mm
Compression Ratio: 9.2: 1
Carburation: PGM-FI electronic fuel injection
Max. Power Output: 8.3kW/8,000min-1
Max. Torque: 11.2Nm/6,250min-1
Ignition: Computer controlled fully transistorised with electronic advance
Starter: Electric
Gearbox: 5-speed
Final Drive: 2.63
Wheels Front: U-cross-section 6-spoke cast aluminium 17M/C x MT1.85
Wheels Rear: U-cross-section 6-spoke cast aluminium 17M/C x MT2.15
Tyres Front: 80/100-17M/C (46P)
Tyres Rear: 100/90-17M/C (55P)
Suspension Front: 30mm telescopic fork, 115mm axle travel
Suspension Rear: Conventional twin shock, double tube damper with 3-step adjustable spring preload, 87mm axle travel
Brakes Front: 240mm hydraulic disc with 2-pod calliper and resin mould pads
Brakes Rear: 130mm leading/trailing drum
Length: 1,955 mm
Width: 760 mm
Height: 1,110mm
Wheelbase: 1,270mm
Seat Height: 792mm
Ground Clearance: 173mm
Fuel Capacity: 13litres
Kerb weight: 128kg
