New Rider Orientation: This section is for new riders, learners, getting licensed, first bikes, insurance queries, training courses, etc.
08-31-2009, 3:52 PM
Bike(s): honda rr 900 (91) Posts: 6
| *Newbie/ Vocabulary* Hey everyone, Saying Hi from Des Moines.
How is everyone? This is just for some people.. please refer to this acronyms and abbreviations..when talkin about nikes & cars, it always helps newbies like me.. I like to know what you're talking about otherwise I'm lost.. add more if you want or start a thread! Quote:
CAI - cold air intakes
WAI - Warm air Intake
SR - Shark Racing
IM - intake manifold
TB - Throttle body
BBTB - Big Bore Throttle Body
MAF - Mass air Flow
MAP - Manifold absolute pressure
AIT - Air intake temperature
AFR - air fuel ratio
ABS - Anti Lock braking system
ATC - Automatic temperature Control
SOHC - Single overhead Cam
DOHC - Dual overhead Cam
OHC - Over head Cam
Evap system - Evaporation System
IAC - idle Air Control
CAT - Catalytic Converter
MAT - manifold air temperature
PFI - port fuel injected
EFI - electronic fuel injection
TPS - throttle position sensor
TBI - throttle body injection
WOT - wide open throttle
A/C - Air Conditioning
ATF - automatic transmission fluid
LSD - Limited slip differential
AWD - all wheel drive
AWS - all wheel steering
O/D - overdrive
Tranny - transmission
HP - horse power
BHP - brake horse power
FWD - front wheel drive
RWD - Rear wheel drive
MPG - miles per gallon
NA - naturally aspirated
RHD - right hand drive
RPM - revolutions per minute
SC - supercharged
SRS - secondary restraint system
TC - turbo charged
ART- air ride technologies
SLL- solar led lights
MIL = Malfunction Indicator Light
RTFM = READ THE FACKING MANUAL
PPM = Parts Per Million (smog term)
GLS-Grand Luxo Super
LS-Luxury Sedan
LX-Luxury
DCCD-Driver Controlled Center Differential (Subarus )
TC-also seen as traction control
EBD-Electronic Brake Distibution
ASC-Automatic Stability Control
ACS-Auto Car stereo
K&N- k&n cold air intake
CFC-Clorofluorocarbons
AWD-All wheel Drive
AVCS-Active Valve Control System
SRS-Secondary Restraint System
DRL-Daytime Running Lights
BLL- battery led lights
VTEC-Variable Valve Timing and Electronic Lift Control
iVTEC-"intelligent" Variable Valve Timing and Electronic Lift Control
WRC-World Rally Championship
FIA-Federation Internationale de l'Automobile
SAE-Society of Automotive Engineers
AEM-Advanced Engine Management
AMG-Aufrecht Melcher Grossaspach (Mercedes Benz racing)
POS- Piece of ***** |
WELCOME.
Have a great day,
Calley
Reason: spelling error
08-31-2009, 3:58 PM
Bike(s): CBR1000rr6 Age: 22 Posts: 632
| Re: *Newbie/ Vocabulary*  and  not to offend you....but were not retards
08-31-2009, 4:09 PM
| Re: *Newbie/ Vocabulary* not to sound like a woman... but i am
haha  |
08-31-2009, 4:10 PM
Bike(s): 1999 CBR 900RR Age: 29 Posts: 886
| Re: *Newbie/ Vocabulary* I'm sorry to hear that...
__________________ That boy's got the Devil in him. |
08-31-2009, 4:13 PM
| Re: *Newbie/ Vocabulary* lmao
__________________  |
08-31-2009, 4:17 PM
| Re: *Newbie/ Vocabulary* i admit the downfalls of the female race
you guys are much smarter when it comes to a lot of things.
true that! |
08-31-2009, 4:22 PM
Bike(s): H0NDA && KAWASAKi Age: 19 Posts: 9
| Re: *Newbie/ Vocabulary* not every female is a dumb***... lol
Reason: none
08-31-2009, 4:28 PM
#8 | | Unleash the POWER!!
Bike(s): Cbr600F4 1999(sold)Repsol Blade 2007 Age: 5 Posts: 9,874
The mind is a funny thing Jazzy's Blog |
08-31-2009, 4:38 PM
Bike(s): 1995 CBR900rr, 1990 GSX-R 750, project Blade Age: 41 Posts: 6,238
| Re: *Newbie/ Vocabulary* Quote:
WELCOME.
Have a great day,
Calley | I used to have a pair of Nikes.... and they didn't have any of that stuff??
maybe I was conned  anyway
__________________ As long as I fall, I don't hit the ground. As long as I fall, I'm safe & sound. |
08-31-2009, 4:40 PM
| Re: *Newbie/ Vocabulary* LOL! thanks for catching that... i meant "bikes" haha..
***ill be back to post pics of my whips later guys! ** stay tuned! |
08-31-2009, 4:40 PM
Bike(s): CBR929, 3xGSXR750, GSXR1000, ZX6R, XS250, KZ750 Age: 43 Posts: 9,512
| Re: *Newbie/ Vocabulary* BHP - HP measured at the crank
WHP - HP measured at the wheel(s)
RWHP - HP measured at the rear wheel(s)
CR - Compression Ratio
PCD - Pitch Circle Diameter (the circle that connects wheel or disc rotor bolts)
You can add some Fireblade specific acronyms:
HVIX - Honda Variable Intake and eXhaust system
HTEV - Honda Titanium Exhaust Valve (part of the HVIX)
HISS - Honda Intergrated Security System
HESD - Honda Electronic Steering Damper
EGCV - Exhaust Gas Control Valve
And some basic mechanical terms:
CCT - CamChain Tensioner
TDC - Top Dead Centre
BDC - Bottom Dead Centre
BTDC/ATDC - Before/After TDC
BBDC/ABDC - Before/After BDC
Deck Height - Height of the engine from crank centreline to head face
Compression Height - Height of a piston (wrist pin centre to flat deck of the crown)
Rod Length - Conrod length (centre of crankpin to centre of wrist pin)
Rod Ratio - Rod length divided by crank stroke
Bore Spacing - Distance between the centres of two adjacent bores
Cam Base Circle - The heel or back of the cam lobe where the valves are not in contact (NB: Installed cams are usually measured at a specified valve opening of 1mm or 0.50")
Cam Lift - Difference between the base circle and lobe
Cam Duration - Degrees of crank travel while intake or exhaust valves are open
Cam Overlap - Degrees of crank travel while intake and exhaust valves are open
Suspension Terms:
Sag - Difference between fork or shock length extended and at rest
Race Sag or Rider Sag - Sag with the rider in position
Compression Damping - Valves controlling fork or shock compression rate
Rebound Damping - Valves controlling fork or shock extension rate
Stiction - Difference between point of rest after extension and compression of fork or shock
08-31-2009, 4:46 PM
| Re: *Newbie/ Vocabulary* wow thanks bladeracer! that's what im talking about..
this is a great forum
learning a lot already... start postin your rides with your posts! |
08-31-2009, 4:49 PM
#13 | | Unleash the POWER!!
Originally Posted by calley03 wow thanks bladeracer! that's what im talking about..
learning a lot already... start postin your rides with your posts! | Best look in the Gallery for that, OR Review my Ride has a lot of great pics
08-31-2009, 5:00 PM
#14 | | I'm a bird.. NOT a bloke!!!
Join Date: 03-15-2008 Location: Everywhere.. via the interweb
Bike(s): Honda, Kawasaki Posts: 8,325
Originally Posted by calley03 you guys are much smarter when it comes to a lot of things. |  No they're not... We just let them believe that Quote:
Originally Posted by JMJ0HNS0N not every female is a dumb***... lol |  |
08-31-2009, 5:07 PM
#15 |
| Re: *Newbie/ Vocabulary* haha, well you men are smart for finding ways for making us believe that you are. that's for sure heh..
i honestly know women cannot survive with out men.. but of COURSE men cannot survive without women
I still think you are a tiny bit smarter.. just because you are a tiny bit less sensitive... in the grand scheme of things-- that makes the BIGGEST difference. I should know :op
you guys are so silly and honest  fun thread. |
09-01-2009, 2:34 PM
#16 | | I'm a bird.. NOT a bloke!!!
Originally Posted by calley03 you guys are so silly and honest  fun thread. | ummmm... I'm a girl......
and.............. Quote:
Originally Posted by calley03 i honestly know women cannot survive with out men.. |  Says who.... I am perfectly capable of looking after myself and my kids.. Quote:
Originally Posted by calley03 I still think you are a tiny bit smarter.. | Was it a man who told you that... cos they're fibbing if they did  |
