how to determine wire polarity - Honda Motorcycles - FireBlades.org
post #1 of 16 Old 03-31-2004, 9:14 PM Thread Starter
stegen's Avatar
I have to wire up a powersupply for our camera tomorrow. i have a 3 prong power cord that has ground, neutral ground and hot. How do i determine which wire is which? the end is cut off and i have to figure out which is which. my dad said something about ohms and i can check the hot by plugging it in and using a voltmeter but what about the grounds?
stegen is offline
post #2 of 16 Old 03-31-2004, 9:52 PM
G-Force Junkie's Avatar
Reputation Power: 22
Re: how to determine wire polarity
I'm assuming it dc voltage? Just put a volt meter across the two hot leads, if it reads positive voltage, then the wire you got the positive (usualy red) test lead on is the positive one.
G-Force Junkie is offline
post #3 of 16 Old 03-31-2004, 11:10 PM
If it's an AC cord normal colors are Black-Hot, White-Neutral, Green-Ground
OntheEdge is offline
post #4 of 16 Old 03-31-2004, 11:36 PM
Fig
Fig's Avatar
Reputation Power: 17
I think you are ready for that there electrical job......
This is where the deadly part comes in.
Fig
Fig is offline
post #5 of 16 Old 04-01-2004, 12:30 AM Thread Starter
stegen's Avatar
Fig
I still have to go through training. the guy that is seting me up with the job is going to teach me everything i need to know
stegen is offline
post #6 of 16 Old 04-01-2004, 12:35 AM Thread Starter
stegen's Avatar
'if it was the normal colors, then i could do it no problem but the colors are all messed up. there a yellow/green, brown, black.
now cant you put a voltmeter on ohms and put pos on the plug end and neg on the wire end and if it shows resistence, its the wrong wire? if its shows 0 resistance, its the same wire?
stegen is offline
post #7 of 16 Old 04-01-2004, 1:10 AM
Fig
Fig's Avatar
To check if a wire on one end is the same as a wire on the other, yes, you put both leads on the ends, and if it shows 0 ohms, then you have the same wire. 0 ohms is a direct short. My point that I was joking about was you have to get the ends on the right wires. You hook a hot wire to ground, and not only will you fry the device, you might make the entire case of it hot, and I don't mean heat hot, electrically hot..
Just make sure you aren't standing barefoot in a puddle of water when you plug this thing in...
Fig
Fig is offline
post #8 of 16 Old 04-01-2004, 1:25 AM Thread Starter
stegen's Avatar
Fig
thanks fig. i will be double checking with a expert on this too to be sure nothing goes wrong. still learning.
stegen is offline
post #9 of 16 Old 04-01-2004, 1:33 AM
Reputation Power: 19
Send a message via AIM to Johnny Diablo
If this is low amp stuff it may turn out funny. If this is high amp stuff or say the outlet on the wall.....I picture all the other forums linking to this site much like everyone slows down to look at a car accident.
by the way if you check ohms on a hot wire you just may blow the meter.
Johnny Diablo is offline
post #10 of 16 Old 04-01-2004, 1:54 AM
Ok, you need to provide more info before you post questions like this. I'm assuming Power supply for a camera= a 110vac transformer that go to something like 6 or 12 vdc? Or is it the wire between a battery pack and the camera? I dont know why your checking the ohms on anything, why are you trying to find the resistance of anything? Or are you using it as a poor mans subsitute to check continutiy??? What type of plug was/is supposed to be on there? Most low voltage dc stuff is two wire, maybe three if youhave some sort of shielding or grounding of a case or something. Have you bought that book I told you to buy yet?
post #11 of 16 Old 04-01-2004, 2:07 AM Thread Starter
stegen's Avatar
its like i am hooking up a powersupply for a pc but hardwire instead of a plug connection. its the exact same thing. regular wall outlet. i have 3 wires, color coding doesnt apply here, i need to find hot, neutral, ground, thats it.
I looked for the book but didnt find it anywhere so i am searching online for it.
stegen is offline
post #12 of 16 Old 04-01-2004, 3:04 AM
Ok, disreguard my PM, I'm way off. So you just got a standard 110 3 prong plug on one end, the other 3 bare wires? Your meter should have a continuity tester, if youtouch your two probes together, its beeps. hold one on the round ground prong of the plug, and touch the other to the other end of the 3 wires, only one will make continuty. Thats your ground. The other two are your nutral and hot wire, in a typical wall recptical, the wider of the two flat prongs is the common ground, and the narrower prong is the hot (Usualy black in 110 vac home wiring). Be carefull, your dealing with enough current and voltage to hurt your self or light your house on fire.
post #13 of 16 Old 04-01-2004, 11:59 AM
Images: 5
Reputation Power: 15
You're looking at Euro color codes. Typically yellow/green = ground; brown = neutral; black = hot.
On a standard plug, the neutral will be the fatter blade of the two. Lower rounded blade is your ground. Smaller vertical blade is hot. On a standard household outlet installed with ground pin at bottom, your neutral will be on the left and hot on the right.
Hope this helps, Stegen. PM me if you have more questions.
CanyonCarver is offline
post #14 of 16 Old 04-01-2004, 6:47 PM Thread Starter
stegen's Avatar
got it to work right without any problems. thanks guys.
stegen is offline
post #15 of 16 Old 04-01-2004, 7:36 PM
showmethebombs's Avatar
OntheEdge, you should check out the Arcade! Holy crap man, you are the gamemaster!
Team Honda - well sorta...
showmethebombs is offline
Human Verification
Search tags for this page
determine dc polarity of 2 wires
how to detect positive wire on a motorcycle
how to determine polarity of a firestorm 24volt battery pack polarity
how to determine positive motorcycle wire
how to determine positive neutral and ground wires
how to determine voltage and polarity of.wire
how to find postive wire without colors
how to know which wire is positive
how to tell the polarity of a wire
power cord hot neutral and ground
Safety wire and pliers... firebladetoronto Road Racing: Club / Amateur 19 03-12-2004 5:32 PM
SWS (Single Wire Systems) figment General Discussion 3 02-03-2004 5:00 PM
How to determine if you are trailer trash... 2OHOH2 Off-Topic 1 11-06-2003 2:18 PM
PAIR Valve - why not just pull the 2 wire SuperDave Honda FireBlade 9 06-06-2003 11:37 PM
Mountain Dew Live Wire showmethebombs Off-Topic 13 05-18-2003 8:20 AM
