Go Back   Honda Motorcycles - FireBlades.org Forums > General Motorcycling > Review My Ride
Review My Ride: Show us your motorcycle! Rate & review owners motorcycles, photos, opinions & feedback section.
POLISHING CLUCTH BASKET
Old 03-26-2009, 11:20 AM
Bike(s): 900rr,1000rr,xr50,z50
Rep: redheadedrider is on a distinguished road (10)
check out where my basket has scuff marks on the inside of the tabs. i made a small flat block out of a paint mix stick an applied some 400 wet/dry paper with some WD-40 then went back over everything with some polishing compound. what are you all thoughts? i figure what i did might not hurt anything, if it would opperate a little smooth
Name:	unpolished basket with scuff marks.jpg
redheadedrider is offline
View redheadedrider's Profile View redheadedrider's Gallery Find More Posts by redheadedrider
Old 03-26-2009, 11:28 AM
Re: POLISHING CLUCTH BASKET
here is the after picture
Name:	polished basket (2).JPG
Old 03-26-2009, 3:27 PM
Bike(s): '03 CBR954, '98 VFR, '92 750ZR, '78 KZ650
Rep: muddysteel will become famous soon enough (74)
Nice work.. Impact - probably none (good or bad). Those scuff marks are due to the clutch discs "pushing" against the basket. They are in one place most of the time - the only time they displace from that location is when you pull the clutch lever in..
This means all of the power from the engine is transmitting through the discs onto the basket - hence the scuffing..
So, polishing the marks out doesn't really gain (or lose) anything - it's not the same thing as smoothing out a valve seat or intake manifold, or polishing out a suspension valve..
muddysteel is offline
View muddysteel's Profile View muddysteel's Gallery Find More Posts by muddysteel My Map Location
Old 03-26-2009, 7:00 PM
cool, can you tell i have some time on hand
Old 03-26-2009, 7:16 PM
denzee's Avatar
Rep: denzee is just really nicedenzee is just really nicedenzee is just really nicedenzee is just really nice (361)
Should be ok as long as very little material is removed. Ducatis being dry clutches, hammer the crap out of the baskets and must be replaced often. Same marks you have except very deep and then the clutch hangs up.
denzee is offline
Old 03-27-2009, 2:32 PM
i used pretty much a whole can of napa parts cleaner on the basket then used compressed air to blow it off- that didn't sound right. im doing some upgrades like a shift kit and slipper clucth. i plan on posting everything later. thanks
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 12:19 AM.
