Originally Posted by CBR929RE and where the hell did you find a white girl with a butt? |
..and more importantly what did you drug her with when you first captured her? mine always end up getting too sick or remembering the time and turns to get back to the bungalow so I end up cutting them loose.
Your photographic content is spot on
But fluorescent lighting sucks...gotta use manual mode, no flash - calibrate white balance with a sheet of paper or something for the condition, then select a low iso and consider getting some kind of monopod or micropod, or breathing like a sniper while snapping. This is the 5$ mans method...by all means listen to the guru above first
