Sigma bike computer on the CBR1000RR
07-28-2004, 1:01 AM
Join Date: 12-21-2002 Location: Talala OK, (north of Tulsa)
Bike(s): 2004 Honda CBR1000RR Age: 40 Posts: 102
Rep:  (10) Rep Power: 6
| Sigma bike computer on the CBR1000RR I just finished installing the Sigma Sport BC1200 bike computer. I made a small mounting plate for the computer and my small outside temp gauge. After getting it all on and programmed with the correct wheel size I was able to check out the stock speedo. With the stock speedo reading 80 the bike computer was reading about 76 if I remember right, that sounds about right. I am sure I will change the stock gearing soon, 15 tooth on order, so the stock one will be off even more.
I like this thing because it will track current speed, top speed, average speed, trip distance, riding time plus some other stuff I do not care about.
It is worth the info to me plus I get a true mph reading. I bought this one for $29.99, cheaper fix than the other speedo reprogram stuff.
07-28-2004, 1:10 AM
Bike(s): Bikeless - for now Age: 61 Posts: 10,812
Rep:   (188) Rep Power: 18
| Re: Sigma bike computer on the CBR1000RR I am both a mountain and road cyclist, but have not used one of these units for awhile - I forget how high (mph) they will register. Definitely much cheaper than a speedo correction unit, but how do you know when you have the true speed dialed in?  |
07-28-2004, 1:27 AM
Bike(s): 03 954 B/Y PCIIIUSB-Scotts-Micron Can Age: 54 Posts: 954
Rep:  (20) Rep Power: 5
| Re: Sigma bike computer on the CBR1000RR Quote: |
Originally Posted by Bacchus I am both a mountain and road cyclist, but have not used one of these units for awhile - I forget how high (mph) they will register. Definitely much cheaper than a speedo correction unit, but how do you know when you have the true speed dialed in?  | Don't know about mph but they read up to 300kph so I'm guessing 200mph.
To calibrate you measure your tyre circumference and key it in to the sigma. It just counts revolutions. It wouldn't account for tyre growth at speed or reduced circumference when cranked over but then neither does the stock speedo. |
07-28-2004, 1:35 AM
| Re: Sigma bike computer on the CBR1000RR Good points RP! I'd forgotten that the bicycle 'puters read that high!  And were as programmable as they are. Could probably get one to be fairly accurate, at a much reduced price from a motorcycle oriented "speedo calibrator".  |
07-28-2004, 1:43 AM
| Re: Sigma bike computer on the CBR1000RR Yeah I've got one I used to have on my VFR before it got written off. I haven't bothered putting it on the 954 yet. One thing I really liked about it was being able to ride through speed traps or along side a cop and be supremely confident of my speed. They are handy on the track too for max speed and approximate lap times. You just set the stopwatch going at the beginning of the session and you can do mental maths to get your lap time. |
07-28-2004, 1:46 AM
| Re: Sigma bike computer on the CBR1000RR Maybe I should have said a more accurate reading than the stock unit as I do not think you can ever get it to 100%. |
07-28-2004, 2:22 AM
Bike(s): A few Posts: 1,000
| Re: Sigma bike computer on the CBR1000RR I've had good luck with the BC800's on several bikes. If I remember right, they are accurate to 183MPH. I have one on the RC30, and also the RC45. I even put one on my YSR50/200 because the stock speedo only goes to 50! Once I get my '04 'blade I'll put one on it, too. Calibration is easy, use the measurements to get it close. The easiest way to get it EXACTLY nailed down is to stop at a milemarker on the highway, reset the tripmeter, then ride for at least 20 miles or so, then compare your tripmeter to the actual distance traveled. Since speed measurement is just a function of distance/time, once you get the WS set right, you're done and it's damn near 100% accurate.
Brian |
07-28-2004, 3:08 AM
Bike(s): 2003 VFR, 2005 MV Agusta F4 1+1 Age: 27 Posts: 3,278
Rep:   (191) Rep Power: 11
| Re: Sigma bike computer on the CBR1000RR is that on a 1krr? never seen the dash before, looks neat |
07-28-2004, 9:48 AM
#9 | | Back From the Ashes!!
Bike(s): '00 RC51 (Possible Resurrection), 93 Seca II(Sold) Age: 31 Posts: 7,724
Rep:   (101) Rep Power: 14
| Re: Sigma bike computer on the CBR1000RR That can come in pretty handy if you want to keep track of lots of different type of info. I use to use one of those on my cannondale and loved the thing to death. Of course it was an older version that could only do speed and max speed but it gets the job done.
Might have to pick me up one of these new units. Anyone know an online place to get one? |
07-28-2004, 10:03 AM
Bike(s): 06 Triumph Sprint ST, Husky SM610,& Gas Gas EC 300 Age: 59 Posts: 871
Rep:  (30) Rep Power: 6
| Re: Sigma bike computer on the CBR1000RR |
07-28-2004, 11:28 AM
07-28-2004, 11:42 AM
Bike(s): '06, '04 ZX10R, '03 954, '95, '98, '00 ZX6R Age: 28 Posts: 464
Rep:  (22) Rep Power: 6
Originally Posted by RPinOZ Don't know about mph but they read up to 300kph so I'm guessing 200mph.
To calibrate you measure your tyre circumference and key it in to the sigma. It just counts revolutions. It wouldn't account for tyre growth at speed or reduced circumference when cranked over but then neither does the stock speedo. | A good way to do this is to mark chalk on the side of the tyre then the ground, and then wheel your bike so it's done 3 or 4 revolutions forward, mark again, then measure along the ground, divide by 3 or 4 etc. This reduces the error greatly and gives you a pretty accurate rolling circumference of the tyre. I guess you're only limited by your tape measure and how far you can roll your bike! |
07-28-2004, 12:25 PM
#13 | | Back From the Ashes!!
| Re: Sigma bike computer on the CBR1000RR I am going to order me one later on... It will be nice to have a second setup for those long rides. It kind of sucks on a long ride only having 1 trip counter b/c I use that one to keep track of the total distance and then the whole gas mileage has to be calculated and remembered from there. Plus a second view of just how fast you are going is kind of handy on those long interstate runs  |
07-28-2004, 3:37 PM
#14 |
Bike(s): 929 Age: 33 Posts: 837
Rep:  (70) Rep Power: 8
Originally Posted by Dragger I just finished installing the Sigma Sport BC1200 bike computer. I made a small mounting plate for the computer and my small outside temp gauge. | Nice setup. Does the temp guage have a remote sensor? I had a temp sensor near that area but it picks up a lot of engine heat. |
07-28-2004, 5:05 PM
#15 | | Back From the Ashes!!
| Re: Sigma bike computer on the CBR1000RR I just picked up a "SIGMA SPORTS 1600 W/CADENCE" off ebay for $26 to my door. One more toy to play with for now  |
07-28-2004, 7:10 PM
#16 |
Originally Posted by TGZ13 I just picked up a "SIGMA SPORTS 1600 W/CADENCE" off ebay for $26 to my door. One more toy to play with for now  | Hehe, cadence. Now you can count the total number of large bumps on your trips too! |
07-28-2004, 7:15 PM
#17 | | Back From the Ashes!!
Originally Posted by FuTAnT Hehe, cadence. Now you can count the total number of large bumps on your trips too! |  |
07-28-2004, 7:19 PM
#18 |
Originally Posted by TGZ13 | Correction, wtf was I thinking. I got Cadence mixed up with a pedometer. It's too early in the morning for me. |
07-28-2004, 7:53 PM
#19 | | Back From the Ashes!!
| Re: Sigma bike computer on the CBR1000RR HAHA I forgive you my brain stopped working when I left work 3 hrs ago  |
07-28-2004, 8:28 PM
#20 |
Bike(s): 2004 CBR1000RR RIP @->->-- Age: 32 Posts: 3,584
Rep:  (98) Rep Power: 8
Originally Posted by FuTAnT A good way to do this is to mark chalk on the side of the tyre then the ground, and then wheel your bike so it's done 3 or 4 revolutions forward, mark again, then measure along the ground, divide by 3 or 4 etc. This reduces the error greatly and gives you a pretty accurate rolling circumference of the tyre. I guess you're only limited by your tape measure and how far you can roll your bike! |
Actually I'd say the greatest limiting factor with this mob is how high they can count the revolutions, 3 or 4 I think you're being generous.  |
07-28-2004, 8:29 PM
#21 |
Originally Posted by TGZ13 I am going to order me one later on... It will be nice to have a second setup for those long rides. It kind of sucks on a long ride only having 1 trip counter b/c I use that one to keep track of the total distance and then the whole gas mileage has to be calculated and remembered from there. Plus a second view of just how fast you are going is kind of handy on those long interstate runs  | Sounds like the perfect excuse to upgrade to a 1000RR, they have two trip counters. |
07-28-2004, 8:53 PM
#22 | | Back From the Ashes!!
Originally Posted by matt232 Sounds like the perfect excuse to upgrade to a 1000RR, they have two trip counters. | I wish I could have the 1kRR for now I would be happy with any newer SS |
07-28-2004, 11:29 PM
#23 |
Originally Posted by EatnAsphalt Nice setup. Does the temp guage have a remote sensor? I had a temp sensor near that area but it picks up a lot of engine heat. | No the temp gauge does not have a remote sensor, that would be better. It does pick up engine heat when stopped but out on the road it seems to work fine and that is mainly what I wanted it for. It is called a motofizz thermo clock. It is $22.00 and can be found on http://www.aerostich.com You will have to search for motorfizz or input cat. # 4222 to find it.
MotoFizz Thermo Clock
This stick-on clock/thermometer instrument is fully waterproof and provides the ambient temperature or current time at a glance. Accurate to +- 1º, it can be set to read in C or F and will display time in either 12 or 24 hour formats. Only 1.5" x 1.75" x .63", the ThermoClock is removable from a snap-in bracket (for remote use or theft prevention) and there’s also a neat auxiliary mounting base to help angle it for easier viewing. Sixteen min/max memories let you know how hot or cold it was at different times. The included button battery runs it for about a year. Range is -40F to +137F. Both an Aero RWH favorite and an exclusive http://www.aerostich.com/isroot/riderwearhouse/Images/4222li.jpg |
07-31-2004, 3:41 PM
#24 | | Back From the Ashes!!
| Re: Sigma bike computer on the CBR1000RR Well I just finished pre-installing my sigma computer and it only took a few minutes. The longest part was doing the calculations to make sure the thing read right. I havent had a chance to test ride it yet but I do have a question.
I put the bike up on its stands and started to slowly spin the front tire till the Odomoter read 1/10 of a mile and then read the computer which also read the same thing. Would this be a good indication that it was configured right or at least close? |
08-01-2004, 7:09 PM
#25 |
Bike(s): 04 1000RR Silver/Black Age: 33 Posts: 198
Rep:  (10) Rep Power: 5
| Re: Sigma bike computer on the CBR1000RR My speedo is 4 off as well. Must be the standard error.
I was thinkin of mounting a compass in that same area, haven't got around to it yet. Looks good  |
08-08-2004, 12:21 AM
#26 | | Back From the Ashes!!
| Re: Sigma bike computer on the CBR1000RR Well I finally got to put some miles on and test out the litte bugger and all i can say is
Rode about 180 miles and its nice having all that data handy. The dual trips was nice b/c I was easily able to keep track of total miles as well as miles since fillup and all other info.
The ride time feature is pretty cool since it only calculates time while in motion. Almost 4 hrs of riding today with the new toy.
I will definately be putting this on my next bike  |
08-08-2004, 12:40 AM
#27 |
| Re: Sigma bike computer on the CBR1000RR Was the speed on your BC about the same as your stock speedo? |
08-08-2004, 5:21 AM
#28 |
Bike(s): 2003 954 (fireblade) 149.3 Hp Age: 45 Posts: 5,183
Rep:  | |
