Road Racing: Club / Amateur: Discussion of Club / Amateur Motorcycle Road Racing, such as AFM, CCS, WSMC, WERA, etc.
05-16-2006, 10:36 AM
#1 | | Das Ende ist hier
Bike(s): One Posts: 2,705
| Lowside Common Themes Reading the lowside stories that have happened over the past month, I've noticed a common theme: poor body position.
For those able to go to Grattan, it might be well worth the monetary savings to get the more experienced riders to give a quick class or two, or a little one on one on the track (if there's time) to try to correct those errors early in the day.
Just food for thought for those lucky enough to be able to get to Grattan this year. |
05-16-2006, 10:45 AM
#2 | | Meatarian
Bike(s): 01 R/B 929 Age: 28 Posts: 12,285
| Re: Lowside Common Themes work on it on the street also. body position can be worked on anytime even at street speeds. who cares if you lean off a bunch on the street and basically have the bike upright in a turn. you don't have to be trying to put your knee on the ground or anything. Just get used to moving around in the seat.
05-16-2006, 10:52 AM
Bike(s): 2000 929 (sold), 2007 GSXR 750 Age: 29 Posts: 461
Rep:  (35) Rep Power: 5
| Re: Lowside Common Themes Nice idea. I have heard of cops giving people a hard time for doing that: Leaning off the seat, not even close to the ground. But then again, I have only heard.
Any opinions on that? |
05-16-2006, 10:59 AM
#4 | | Meatarian
| Re: Lowside Common Themes I doubt there's any laws against it. and who cares if you look stupid hanging off a bike at 30mph 2 feet away from the ground. I've done it. I say go for it.
05-16-2006, 1:40 PM
#5 | | Close encounter of the wool kind
Bike(s): '04 CBR1000RR, '84 Ascot, '02 RC51 Posts: 13,839
| Re: Lowside Common Themes  I know I need to improve that and foot position (my two largest screw ups in my opinion) Pointers are welcome at Grattan.
Does this mean you or the Ms are coming Seamus?
Send maple |
05-16-2006, 2:14 PM
| Re: Lowside Common Themes Body position is a big factor and not necessarily for the obvious reason (moving the CG to go around a corner with less lean angle).
Proper body position requires proper foot position and being smooth during the transition from one side of the bike to the other. If you pivot around the tank from side to side, you are keeping your weight well forward and causing the smallest amount of external influence to the bike which can and will upset it while heading for the apex.
If you break body positioning down into it's component parts and work on each component individually you will be better able to accomplish something that may seem drastic at first, but become second nature over a short period of time.
Without getting into a dissertation on downshifting and trail braking, I would say the components are as follows (in a loose order):
1: Approach the corner and start your downshifting/braking
Note: Do not lock your arms, but keep them loose and bent at the elbows and make certain you are "toes only" on the pegs.
2: Put your leading shoulder forward (inside shoulder)
3: Slide around the tank (pivoting) to the point where you get 1 cheek totally off the seat
4: Throw it in (countersteer to begin turn in) and begin the transition to no brakes and neutral throttle
5: As you approach (and reach) the apex (and full lean) begin picking up the throttle very smoothly
6: The bike will begin to stand back up under throttle, so you pivot back to neutral (or other side in a transition) again as smoothly as possible
Put all of these together until it becomes one fluid motion and you will minimize loosing the front end on corner entry. Avoid any sudden brake or throttle changes mid corner as these will either overload or unload the front tire. |
05-16-2006, 2:59 PM
#7 | | Mr. Brownstone
| Re: Lowside Common Themes You forgot:
4.5) throw your foot out as if you're gonna catch the bike and go flat-track style.
Hey, if it works for Rossi and Pedrosa it should work for me, right? |
05-16-2006, 3:03 PM
| Re: Lowside Common Themes Quote: |
Hey, if it works for Rossi and Pedrosa it should work for me, right? | That is discussed in chapter 5 . . . |
05-16-2006, 3:14 PM
#9 | | Mr. Brownstone
| Re: Lowside Common Themes Oh, right. Isn't chapter 4 all about how to veddy veddy good speak the English? |
05-16-2006, 3:21 PM
Originally Posted by BDA116 Oh, right. Isn't chapter 4 all about how to veddy veddy good speak the English? | Engrish |
05-16-2006, 3:36 PM
Bike(s): 04 600RR, 03 XR50, 05 TC250 Age: 65 Posts: 4,668
Originally Posted by BDA116 Oh, right. Isn't chapter 4 all about how to veddy veddy good speak the English? | Have you been drinking again BDA? (You need to click the pic to read the label) |
05-16-2006, 3:46 PM
#12 | | Mr. Brownstone
| Re: Lowside Common Themes My eyes aren't that bad, I can read the label without clicking just fine.
That's old news. Remember Wasatch is a local brewery, and they have billboards everywhere. That's one of their old mixes.
I'd come up with a jab for you, but I'm not witty enough. |
05-16-2006, 4:02 PM
#13 |
Originally Posted by BDA116 My eyes aren't that bad, I can read the label without clicking just fine.
I'd come up with a jab for you, but I'm not witty enough. | You can read everything on there (not just the main name)? from the thumbnail?  |
05-16-2006, 4:05 PM
#14 | | Mr. Brownstone
| Re: Lowside Common Themes Are you calling me a liar? |
05-16-2006, 4:11 PM
#15 |
Originally Posted by BDA116 Are you calling me a liar? | Do you think I called you a liar? |
05-16-2006, 4:47 PM
#16 | | Das Ende ist hier
Originally Posted by CBR929RE work on it on the street also. body position can be worked on anytime even at street speeds. who cares if you lean off a bunch on the street and basically have the bike upright in a turn. you don't have to be trying to put your knee on the ground or anything. Just get used to moving around in the seat. | I've been doing just that. Haven't passed Johnny Law while doing yet but did get a wild stare from the FT Sill gate guards. There's an exit ramp that leads right to one of the main gates. Quote: |
Originally Posted by sheepofblue Does this mean you or the Ms are coming Seamus? | Quote: |
Originally Posted by seamus Just food for thought for those lucky enough to be able to get to Grattan this year. |  |
05-16-2006, 5:08 PM
#17 | | Close encounter of the wool kind
| Re: Lowside Common Themes I have passed them coming down the mountain but most county mountain cops are fairly cool if you are behaving decently.
Send maple |
05-16-2006, 5:12 PM
#18 | | Blow me.
Bike(s): 998RR4 Age: 26 Posts: 11,500
Originally Posted by RRWANTR Have you been drinking again BDA? (You need to click the pic to read the label) | "Why Have Just One?"  |
05-16-2006, 5:51 PM
#19 |
Bike(s): SV650S Posts: 5,710
Originally Posted by phobiaphobe "Why Have Just One?"  | Maybe it should be "One will f*** you up, so imagine what half a dozen would do."
Is a paradigm worth 20 cents?
05-16-2006, 6:00 PM
#20 | | I found the cure for hope
Bike(s): SV650 Age: 33 Posts: 1,374
Originally Posted by tigerblade Maybe it should be "One will f*** you up, so imagine what half a dozen would do."  | HEY!
peas to the kilometers
05-16-2006, 6:09 PM
#21 |
Originally Posted by Sunbert HEY! | I didn't mean you, baby. Those other girls.
05-16-2006, 6:14 PM
#22 | | Mr. Brownstone
Originally Posted by tigerblade I didn't mean you, baby. Those other girls.  | I don't know man, I mean look at her picture. |
05-16-2006, 6:15 PM
#23 | | Just repeating what ever I hear... | |
