Go Back   Honda Motorcycles - FireBlades.org Forums > Motorcycle Racing > Road Racing: Professional
Road Racing: Professional: Discussion of Professional Motorcycle Road Racing, such as MotoGP, AMA, World SuperBike, etc.
*SPOILER* World Superbike
Old 02-27-2006, 12:12 PM
  #31
ReaperAZ's Avatar
Bike(s): I used to be cool.
Rep: ReaperAZ is just really niceReaperAZ is just really niceReaperAZ is just really niceReaperAZ is just really nice (350)
Send a message via AIM to ReaperAZ Send a message via MSN to ReaperAZ Send a message via Yahoo to ReaperAZ
Re: *SPOILER* World Superbike
Originally Posted by BDA116
When are they gonna upgrade their shitty-at-best broadcast technology? That euroland technology is worse than some ten year old AMA races I recorded on videotape from the T.V.
If the racing weren't exciting to watch I wouldn't be able to stand watching this crap. It's far worse than any mp3 recording.
Colors washed out, frame rate horrible and distorting every view as they come across the scene, blurry. It's just plain horrid. I've seen better quality video from home camcorders in the early nineties.
Seriously, get with the friggin' times. Seeing Olympic coverage on NBC back to back with this is beyond a joke.
Whew, I thought SPY's TV was crapping out on him.
ReaperAZ is offline
View ReaperAZ's Profile View ReaperAZ's Gallery Find More Posts by ReaperAZ
Old 02-27-2006, 12:13 PM
  #32
SJ96F3's Avatar
Bike(s): 1996 CBR600F3
Rep: SJ96F3 has a spectacular aura aboutSJ96F3 has a spectacular aura aboutSJ96F3 has a spectacular aura about (248)
As for Barros they said he struggles with the starts because the superbikes have significantly less technology than the GP bikes and it'll take him a while to adjust. I guess the starts are where this lack of technology is most evident. They said he was lapping as quickly as the lead group... just started way back.
SJ96F3 is offline
View SJ96F3's Profile View SJ96F3's Gallery Find More Posts by SJ96F3
  #33
RRWANTR's Avatar
Bike(s): 04 600RR, 03 XR50, 05 TC250
Rep: RRWANTR is a splendid one to beholdRRWANTR is a splendid one to beholdRRWANTR is a splendid one to beholdRRWANTR is a splendid one to beholdRRWANTR is a splendid one to beholdRRWANTR is a splendid one to beholdRRWANTR is a splendid one to behold (727)
Try again boofy. Their format is FAR worse than ours, and the broadcast systems used during both SBK and MotoGP events are even worse. If you actually used those couple brain cells you had you could come up with a good answer.
The local official broadcasts of the Olymipcs were in the shitty format, yet came across crystal clear.
Find someone that actually works in broadcasts and has full knowledge of them (like my younger brother who is just getting home from working in Torino for the Olympics and does solid work for the ESPN channels, NBC and others) and they could tell you just watching what is wrong with the systems.
Go back to your hole where people actually buy into your all-knowing horseshit.
I thought Eurpean tv actually was broadcast at a higher res then here?
RRWANTR is offline
View RRWANTR's Profile View RRWANTR's Gallery Find More Posts by RRWANTR
Old 02-27-2006, 12:14 PM
  #34
Mr. Brownstone
Bike(s): 05 600RR
Originally Posted by deez
And read above from someone who lives there "Picture quality here is usually excellent"
Now back to your regularly scheduled hatred of everything but yourself
Ah yes, typical boofy deflection of truth and fact.
Picture quality may be excellent compared to what they normally get, but that doesn't mean it's excellent compared to what is normally seen for brodcasts here.
Back to your regular scheduled nose up the ass of anything anti-American.
RR, I won't even pretend to know all the technical differences, but I have a brother that makes a living doing so. He's gone off about why euro broadcasts look so horrid in the past, and was laughing at the local broadcast equipment used during the Olympics, although they were better quality than normal over there.
At any rate, the technology is lacking there and isn't close to the same resolution typically seen from the big broadcast companies here.
BDA116 is offline
Old 02-27-2006, 12:29 PM
  #35
ReaperAZ's Avatar
Good to hear his lap times are on par with the lead guys. I hope he can get some decent starts and battle it out with the Troy's
ReaperAZ is offline
Old 02-27-2006, 12:31 PM
  #36
RRWANTR's Avatar
I knew PAL had a higher vert res. So, if the tv's capable of showing a better picture, it must be the cameras and broadcasting equip that are not up to par if the pic is worse.?.?.?
NTSC is based on a 525-line, 60 fields/30 frames-per-second, at 60Hz system for transmission and display of video images. This is an interlaced system in which each frame is scanned in two fields of 262 lines, which is then combined to display a frame of video with 525 scan lines. NTSC is the official analog video standard in the U.S., Canada, Mexico, some parts of Central and South America, Japan, Taiwan, and Korea.
PAL is the dominant format in the World for analog television broadcasting and video display and is based on a 625 line, 50 field/25 frames a second, 50HZ system. The signal is interlaced, like NTSC into two fields, composed of 312 lines each. Several distinguishing features are one: a better overall picture than NTSC because of the increased amount of scan lines. Two: since color was part of the standard from the beginning, color consistency between stations and TVs are much better. There is a down side to PAL however, since there are fewer frames (25) displayed per second, sometimes you can notice a slight flicker in the image, much like the flicker seen on projected film. Countries on the PAL system include the U.K., Germany, Spain, Portugal, Italy, China, India, most of Africa, and the Middle East.
RRWANTR is offline
Old 02-27-2006, 12:38 PM
  #37
Mr. Brownstone
Bike(s): 05 600RR
I just called him and asked for a simple explanation and it all has to do with the raw formats of the production equipment. EVERYTHING is translated to a final format depending on where it is going, but the raw camera recordings and production formats are the difference. The translated T.V. format doesn't really matter much. Where it counts is the equipment quality and their native raw formats.
BDA116 is offline
Old 02-27-2006, 12:42 PM
  #38
RRWANTR's Avatar
So, my assumption didn't make and ass of me....sweet.
RRWANTR is offline
Old 02-27-2006, 12:58 PM
  #39
QuikMike's Avatar
Bike(s): A loud, booming twin.......
Rep: QuikMike will become famous soon enough (77)
Send a message via Yahoo to QuikMike
no respect for the reigning world champ (and my prediction to take the title), Troy Corser!!???.......in race two, his front tire was done, but he was still able to hold Bayliss off(who was riding the wheels off that Duc)....give Corser some love!!!
QuikMike is offline
View QuikMike's Profile View QuikMike's Gallery Find More Posts by QuikMike
Old 02-27-2006, 1:03 PM
  #40
RRWANTR's Avatar
You don't think Bayliss' tires were just as done?
RRWANTR is offline
Old 02-27-2006, 1:27 PM
  #41
Proto's Avatar
Bike(s): CBR954RR & BSA Bantam D1 (1953!!) and a LOOK 585
Rep: Proto is a glorious beacon of lightProto is a glorious beacon of lightProto is a glorious beacon of lightProto is a glorious beacon of lightProto is a glorious beacon of light (450)
Maybe it's time BDA bought a new TV
Proto is offline
View Proto's Profile View Proto's Gallery Find More Posts by Proto
Old 02-27-2006, 1:39 PM
  #42
RRWANTR's Avatar
Naa...he explained it. It's the production equipment they use over there, not the tv. The pic quality of the races DOES suck compared to the normal programming over here.
RRWANTR is offline
Old 02-27-2006, 1:46 PM
  #43
Mr. Brownstone
Bike(s): 05 600RR
Need a new T.V.? Sure, why not. Question is, which of the six I currently have should I upgrade?
BDA116 is offline
Old 02-27-2006, 1:49 PM
  #44
RRWANTR's Avatar
Replace the plasma or lcd and send the old one to me.
RRWANTR is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 8:57 AM.
