| Re: Balancing Beads question The theory is OK but I am skeptical of how well they would move within the tire. Everyone I know uses gravity balancers on track bikes (including at the AMA races). For your VTX a well balanced tire might give you a bit smoother ride, be easier on suspension and decrease tire wear. None of those would be huge IF they installed your tire correctly. There is a balance dot on the tire, it should be at the valve stem if it is not then the tire could be way out of balance (the dot indicates the light spot and not all brands have it) Personally I would recommend gravity balance with stick on weights for spokeless rims and the spoke weight for spokes. This would at worst cause no harm and at best give the improvements above.
