Good through 2/10/2008...
GALFER STAINLESS FRONT LINES w/ HH PADS + FREE Motul 5.1 fluid!
Galfer braided stainless lines are a massive improvement over stock rubber
brake hoses. Remember that with rubber brake hoses, the line must
flex/expand before any braking pressure can be applied to the pistons,
slowing down response time and making the lever feel "spongy". Galfer's
2-line racing kits come with all necessary hardware & washers to change
Out the stock stuff. Lines have silver fittings and your choice of clear,
black, dark smoke, blue, yellow, orange, green, or red outer coating.
New for 2008, Galfer can do kits with colored banjo fittings and colored banjo bolts. Anodized colors include gold, blue (fittings only), red, or black. NOTE: All color options except silver/clear requires a 2-3 WEEK build-to-order lead time with Galfer.
The deal includes Galfer's 1375 HH brake pads (the proper set to do both calipers for the front) for a great package. The HH compound is a sintered bronzed base material that includes graphite and advance ceramics. It will provide instant powerful controlled braking force at any speed or temperature, rainy or dry weather. Great lasting power for track days, racing, and aggressive street riding where you want immediate stopping power. Compared to the 1370 HH compound, the 1375 compound has a new ceramic back coating for further thermal resistance and less heat transfer to your pistons/fluid!
For a step up in brake fluid performance, we're including a bottle of
Motul 5.1 fluid (compatible with DOT-3 and DOT-4 fluids). Compared to the lower boiling points of stock D3/D4 brake fluids, Motul 5.1 has a higher boiling point (365 deg F) BUT is more stable (less hydrophilic - meaning less water absorbing) over time than the racing fluids which must be changed out frequently.
Front line kit + front pads + 1 bottle (.5L) Motul 5.1 Brake Fluid:
NEW 2008 RETAIL PRICE: $190-233
Sale: CALL/EMAIL FOR PRICE
(Note: 4-pad calipers +$40)
(Colored anodized fittings + $10)
(Colored anodized bolts + $15)
Add SS rear brake or clutch line to either kit above, also at a discounted sale price!
Add semi-metallic (black compound) rear brake pads (we suggest this over HH rear pads due to the low thermal-demand tolerance of most OEM rear rotors AND the fact that unless you're racing you rarely use the rear and would be better served with a longer-life pad)
POST UP (for a PM), OR CALL OR EMAIL FOR A QUOTE ON ADDING WAVE ROTORS TO THE KIT!!!
CHICKEN HAWK TIRE WARMERS: $379.99 (retail $450!)
Cal-Sportbike >>> Speedo Healer, Pipercross Air Filters, Galfer Brakes, Gear Indicator Pro, Elka Suspension.
The best tire warmers you can get, Chicken Hawk is the warmer of choice for many AMA champions!
PERFORMANCE: Properly heated race tires allow faster cornering from the first lap
ECONOMY: Properly heated race tires wear longer and won't get ripped up on the first lap. Tire warmers also "ease" heat cycles with less dramatic warming and cooling
Chicken Hawk tire warmers have the highest watt-density rear warmers draw 600 watts, fronts draw 550 watts for the most watts/square inch available! The result is a slow gradual yet powerful warmer that more efficiently permeates the entire carcass with thorough and stable heat
STANDARD WARMERS
* Tough 1000-denier Cordura outer shell
* Inner lining is made of melt-proof aramid fiber
* High-impact temperature controllers and full coverage Kapton heating elements combine with Nomex insulation to keep heat from escaping and diffuse it to heat the whole tire surface
* Neon light glows when unit is powered; blinks when tire reaches full temperature (174 degrees F)
POLE POSITION WARMERS
* All the features of the standard warmers, plus a hard-shell carry case and a sensor that offers a choice of three operating temperatures
* Use the low (135 degree F) setting for maintaining heat cycles during extending periods of time between track sessions
* Use the medium (155 degree F) setting heating rain-compound tires; also perfect a quick run into the pits if a start is delayed
* Use the high (174 degree F) setting to bring tires up to proper temps for dry race track conditions
NOTES:
1) NOT recommended for street use
2) Do not use a tire warmer on a smaller tire than it was designed for....overlapping or bunching a warmer will damage the warmer and the tire.
3) 125GP warmers are made for tires used on 125GP bikes. These tires have a different density carcass and require specific warmer sizes and heating calibrations which are not appropriate for other tires.
SIZING CHOICES
125GP: 17" rim, 80-100 front, 105-115 rear
250GP: 17" rim, 110-120 front, 150-165 rear
Superbike: 17" rim, 110-120 front, 170-190 rear
SOLD IN PAIRS
SHOGUN SLIDERS - CRASH KITS: Retail $79.99-$204.99
Sale price $62.99-up!
Shogun Crash kits include Frame Sliders, Bar end sliders and swing arm spools for most popular late model sport bikes. These kits are available in black and come complete in a single package. They offer the best value in both price and protection.
* Some models may require body modification.
ICON LEATHER RIDING JACKETS: Call/Email for sale price!
Icon leather riding jackets have CE-approved armor, premium cowhide, and some (like the new Accelerant) have removable insulated windproof liners and zippered vents.
Further Icon is still defining their own style in motorcycle apparel, with eye catching designs and great graphics.
During this sale, ALL Icon leather jackets are on sale.
________________________________________
Shipping is via UPS Ground insured, ranging from $9-14 to most US locations. We only charge sales tax in ID. International orders will ship USPS (see rules/restrictions on our "policies" page)
Order on our website to get the sale price. On the items that required a price quote via phone or email, just enter the price quoted in the comments during checkout.
* Note: All sales are final on special sale items. No refunds or exchanges, so please be sure on your sizing prior to ordering!
