G6 Forks - What should I do?
Old 05-03-2006, 8:24 AM
Just repeating what ever I hear...
Heavy-Dee's Avatar
Bike(s): 2004 GSXR 600
Rep: Heavy-Dee has much to be proud ofHeavy-Dee has much to be proud ofHeavy-Dee has much to be proud ofHeavy-Dee has much to be proud ofHeavy-Dee has much to be proud ofHeavy-Dee has much to be proud ofHeavy-Dee has much to be proud ofHeavy-Dee has much to be proud ofHeavy-Dee has much to be proud of (1112)
Send a message via AIM to Heavy-Dee
Guys I need help. At the races this past weekend I think I was bottoming out my forks. Even if I wasn't, the bike was very unsettled under braking over bumps. I was even dragging the lower a bit. Hell, it didn't like bumps at all. I tried some suspension tweaking, however the stock adjustments for compression and rebound leave quite a bit to be desired. Meaning, I only have about 3 turns in each. Furthermore, there wasn't a huge difference when going full "on" to full "off".
Here are my options that I'm trying to sort through.
1. Per Abtech's advice some time ago, respring for my weight w/ fresh oil. I could probably do this myself and would be pretty cheap. Cheapest option other than "do nothing".
2. Send the forks to be resprung and revalved (?) by one of the well known suspension guru's. Thermosman wants $450 for this.
3. Purchase a used set of forks from a guy on WERA who claims that they have "over $800 worth of 20mm Penske internals". He wants 400 w/ a trade for my stock forks.
4. Send my forks to the known suspension guru and have the Ohlins internals put in. Thermosman wants 700 for this.
5. Do nothing. Deal with it. I'll appreciate better suspension even more after racing one more year on the stockers.
So gang, what do you think?
Heavy-Dee is offline
View Heavy-Dee's Profile View Heavy-Dee's Gallery Visit Heavy-Dee's homepage! Find More Posts by Heavy-Dee My Map Location
Old 05-03-2006, 8:32 AM
abtech's Avatar
Bike(s): 2007 RC51
Re: G6 Forks - What should I do?
Stay away from anything with the Axxion valves (option 3). Trackoholic had the Ohlins cartridge put in and it was never right, he eventually went back to stock. I say send them out to Thermosman and have them revalved and sprung.
abtech is offline
Old 05-03-2006, 8:38 AM
Heavy-Dee's Avatar
I respect your opinion, so that's enough to make me cross that option off the list. I'll contact that dude now.
Thanks Ab.
Old 05-03-2006, 8:52 AM
ND4SPD's Avatar
Bike(s): '84 Magna V30
Get 'em revalved w/ stiffer springs. Made a huge difference for me.
ND4SPD is offline
Old 05-03-2006, 9:13 AM
abtech's Avatar
Bike(s): 2007 RC51
But what about your shock? Did you upgrade that as well?
abtech is offline
Old 05-03-2006, 9:19 AM
Heavy-Dee's Avatar
Old 05-03-2006, 9:21 AM
ND4SPD's Avatar
No. According to DK at Grattan '04 the stock shock was good enough for my weight.
ND4SPD is offline
Old 05-03-2006, 10:23 AM
abtech's Avatar
Bike(s): 2007 RC51
Maybe the spring is in the ballpark, but in terms of keeping the wheel on the ground during transitions and bumps (can you say Nelson Ledges?), it's not even close . . .
abtech is offline
Old 05-03-2006, 10:30 AM
Mr. Brownstone
Bike(s): 05 600RR
The valving on the 600RR shock is supposed to be pretty good, but I'm sure the fluid at the very least is broken down by now. I understand DK can work voodoo on the OEM shock and make it sweet for not much cashola.
But I think HD should send his forks off to Thermosman.
BDA116 is offline
Old 05-03-2006, 10:40 AM
ND4SPD's Avatar
Maybe the spring is in the ballpark, but in terms of keeping the wheel on the ground during transistions and bumps (can you say Nelson Ledges?), it's not even close . . .
Yeah, notice I said good enough. It's in the mod plan to get it swapped out. I'm waiting 'til this fall's "clearance" sale on the boards when I can pick up a used one for relatively cheap and get it freshened up.
ND4SPD is offline
Old 05-03-2006, 10:49 AM
Heavy-Dee's Avatar
For which option?
450 or 700?
HD
Old 05-03-2006, 10:55 AM
Mr. Brownstone
Bike(s): 05 600RR
Just go with the $450 option. While I don't know the GSXR forks all that well, I don't think you're going to need the Ohlins internals any time soon.
Just doing the springs and valves will make such a night and day difference and your confidence in the front of your bike will skyrocket.
KISS for now, but don't go with another guy's used stuff where you'll still have questions.
BDA116 is offline
Old 05-03-2006, 11:37 AM
Hammer's Avatar
Bike(s): GSXR Stunt Bike
Rep: Hammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud of (1355)
T man did my forks and so far I like them, they are conciderably harder than stock.
Same price $475 for everything. (shipping back to me)
Hammer is offline
Old 05-03-2006, 1:46 PM
Bike(s): '02 954 05DRZ400S
Rep: 954inMN is on a distinguished road (25)
Personally I would do the $450 revalve too. I don't think respring alone will solve your problems, but it might if your fluid is bad enough.
BUT- You could respring and do the fluid (it will take you 2 hours if you go slow). It would cost 120 bucks or so and you won't have to screw around with shipping. If you send them in they will be resprung anyway so the only money you lose by respringing and doing the fluid yourself is the fluid cost and the time you spend.
Maybe just call T man and see what spring he recommends and install them. If it isn't good enough send them in. Maybe you make it through the season and you can mail them in December or something.
954inMN is offline
View 954inMN's Profile View 954inMN's Gallery Find More Posts by 954inMN
Old 05-08-2006, 10:21 PM
  #15
Heavy-Dee's Avatar
Well, what did HD decide to do, and how is he financing it?
HD
ID:	19178  Click image for larger version
ID:	19179  Click image for larger version
Old 05-09-2006, 12:08 AM
  #16
Mr. Brownstone
Bike(s): 05 600RR
You sent them to Thermosman for springs and a revalve.
And you're pimping out your wife.
But damn, those are good looking decals.
BDA116 is offline
Old 05-09-2006, 9:57 AM
  #17
Heavy-Dee's Avatar
Not yet, but today.
No, but not a bad idea...
Yea, I got them from some asshat.
HD
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 2:14 PM.
