ROM THE MAKERS OF THE SPEEDO HEALER....NOBODY ELSE EVEN MAKES ONE LIKE IT!
Built-in Advanced ("Smart") TRE means no loss of gear indicator function to use a TRE on your Suzuki bike!
MSRP $149.99....early release sale just $119.99!!
http://www.calsportbike.com/images/gipro_500w.jpg
* Advanced "smart" TRE automatically switches off when bike is in neutral means smoother idle and less engine heat
* User can disable TRE with the touch of a button
* Auto brightness control: the sensitivity can be even fine tuned
* Can be set for 5th or 6th gear map at the touch of a button for compatibility with ALL Suzuki models!
* Always indicates the selected gear. It's not like others which don't work when the clutch is pulled in
* Selected gears are shown instantly with NO LAG
* True plug-n-go...Installation takes only 10 minutes on most models
* Auto Stand-by: when ignition is turned off, unit enters into low power
mode and consumes 3mA only (less than a LED)
* In TRE mode the bike's top speed limiter is disabled and throttle response is better in 1st through 4th gear
* Auto Learn function: Unit is pre-programmed to suit most Suzuki bikes.
However, if needed, the unit Learns the gear positions automatically. This ensures compatibility with all Suzuki EFI bikes
* Robust design: waterproof housing; Flash memory (non-volatile) to store user settings; in case of connection or power failure, the TRE mode reverts back to Normal operation
* 30 day money-back guarantee & 2 year replacement warranty
* More info: Heal Tech Electronics Website (
http://www.healtech-electronics.com)
