2006 GSXR 600 rpm problems
08-17-2006, 3:24 PM
Bike(s): 2006 GSXR 600 & 1997 Ducati 748 Posts: 3
| 2006 GSXR 600 rpm problems I have a 06 600 with 500 miles that I just set up for the track. When I am going down the straights the bike will not go over 9,000 RPM's, and it seems the bike is starving for fuel, but still is very responsive in lower RPM's. I had done basic race prep items to the bike, but nothing real major. Let me know of any ideas. Thanks |
08-17-2006, 3:32 PM
Bike(s): '06 CBR1000RR, '06 CRF450X, '06 CRF100 Posts: 5,998
| Re: 2006 GSXR 600 rpm problems Take it back to your dealer for the recall on the power band. |
08-17-2006, 3:53 PM
#3 | | Blow me.
Bike(s): 998RR4 Age: 26 Posts: 11,500
| Re: 2006 GSXR 600 rpm problems ping purpdust |
08-17-2006, 4:28 PM
#4 | | Activate Interlock, Dynotherms Connected
Bike(s): 05 GSXR1000 Y/B, 06 GSXR750 B/W Age: 33 Posts: 1,528
| Re: 2006 GSXR 600 rpm problems Quote:
Originally Posted by timmy422 I have a 06 600 with 500 miles that I just set up for the track. When I am going down the straights the bike will not go over 9,000 RPM's, and it seems the bike is starving for fuel, but still is very responsive in lower RPM's. I had done basic race prep items to the bike, but nothing real major. Let me know of any ideas. Thanks | Did you by chance disconnect the Clutch Switch? This will lower the rev limiter to protect it from redlining when not in gear. (looks like Suzuki read Stegan's post  )
What did you do to it to track prep it?
I have a almost track preped 750 so it is very similar.
Purp |
08-17-2006, 4:31 PM
Originally Posted by Purpdust Did you by chance disconnect the Clutch Switch? This will lower the rev limiter to protect it from redlining when not in gear. (looks like Suzuki read Stegan's post  )
Purp | Interesting about lowering the rev limiter. On the RC it kills the ignition circuit. I guess a total no start condition would be easier to trace than a curious "won't rev past x000 rpm . . ." situation. |
08-17-2006, 4:31 PM
#6 | | Activate Interlock, Dynotherms Connected
| Re: 2006 GSXR 600 rpm problems If you have a Power Commander there is a special procedure that the tured must follow. Make sure they request this from Dynojet before they tune your bike. If you downloaded a map from the net it may also cause you problems.
The problem has to do with the PC3 overloading the lower injectors at high RPMs causeing them to shut on and off. This also could create the problem you are getting. For this try loading a zero map and see if the problem still exist. |
08-17-2006, 4:34 PM
#7 | | Activate Interlock, Dynotherms Connected
Originally Posted by abtech Interesting about lowering the rev limiter. On the RC it kills the ignition circuit. I guess a total no start condition would be easier to trace than a curious "won't rev past x000 rpm . . ." situation. | You need to close the circuit to get the bike to start but then is has a lower redline. What most people are doing is just running those two line from the main harness to the clutch. An alternative is to mount a switch that you manually turn on to start them off to get full RPMs. |
08-17-2006, 4:37 PM
Originally Posted by Purpdust You need to close the circuit to get the bike to start but then is has a lower redline. What most people are doing is just running those two line from the main harness to the clutch. An alternative is to mount a switch that you manually turn on to start them off to get full RPMs. | Sounds like the "let a friend ride your bike" switch  . |
08-17-2006, 4:39 PM
#9 | | Activate Interlock, Dynotherms Connected
Originally Posted by abtech Sounds like the "let a friend ride your bike" switch  . |  Good thinking  |
08-17-2006, 5:06 PM
Purp | I did disconnect the clutch switch along with the kickstand switch. I closed the circuit on the kickstand switch but did not do anything with the clutch because it started up without pulling in the clutch. I will try reconnecting the wire and see if that is the problem. Thanks for the help. |
09-25-2006, 11:22 AM
Bike(s): 2006 Gsxr 600 Red and Black Age: 21 Posts: 22
Rep:  (13) Rep Power: 0
Originally Posted by timmy422 I did disconnect the clutch switch along with the kickstand switch. I closed the circuit on the kickstand switch but did not do anything with the clutch because it started up without pulling in the clutch. I will try reconnecting the wire and see if that is the problem. Thanks for the help. | Yea from what i have read that is your problem. Quite a few guys have done that and had a problem.
This is the first time i have heard the the PC3 messing them up tho. |
09-28-2006, 7:48 PM
| Re: 2006 GSXR 600 rpm problems It helped it...and I unhooked my servo and wire tied it open...bike runs awesome now!!  |
10-28-2006, 10:21 AM
#13 |
Bike(s): k6 GSXR750, 97 YZF1000, 05 600RR, 02 954 Posts: 1,242
Rep:  (29) Rep Power: 4
| Re: 2006 GSXR 600 rpm problems I was just bout to ask that about the 750k6. Thanks already. |
