Front brake problem
Old 04-06-2008, 12:43 PM
Bike(s): 2005 gsxr 600
Rep: mab5155 is on a distinguished road (10)
Front brake problem
Ok I have replaced brakes many times before and now i am having trouble on my 05 gsxr 600. I bought the bike wrecked and i am fixing it up. When i bought the bike the front brakes had to be pumped for them to work. I tried bleeding the lines and that did not fix the problem. I took everything apart and took it off. Ive replaced the calipers and the master cylinder and even got a mity vac and speedbleeders. After reinstalling everything and bleeding the lines. I still have no pressure on the lever at all. Everything is connected correctly. Is there something i should try or do differently. When the lever is pulled back the caliper pistons barely move. Im thinking that i am not bleeding correctly. If that is the case Could someone explain a way of bleeding correctly. Ive done this many times but it just wont work now. Any help will be appreciated.
mab5155 is offline
View mab5155's Profile View mab5155's Gallery Find More Posts by mab5155
Old 04-06-2008, 1:51 PM
Bike(s): cbr1000rr4
Rep: jokke1747 is on a distinguished road (10)
Re: Front brake problem
i believe it has a radial master cylinder right? did you check if it has a bleeding nipple on the master cylinder?
jokke1747 is offline
View jokke1747's Profile View jokke1747's Gallery Find More Posts by jokke1747
Old 04-06-2008, 2:03 PM
It does have a bleeding nipple. Ive already bled the master cylinder as well. I dont know what else to do. There is no pressure on the lever no matter how much i bleed it. Even if i where bleeding correctly there would be some pressure right? Its like the calipers wont close.
mab5155 is offline
Old 04-06-2008, 2:12 PM
rokitt51's Avatar
Bike(s): 97 YZF1000, 02 954
Rep: rokitt51 will become famous soon enoughrokitt51 will become famous soon enough (111)
Sounds like a prob with the calipers or either somethin blockin the lines. The problem just sounds wierd as hell. You should be getin some action if youre doin it right.
rokitt51 is offline
View rokitt51's Profile View rokitt51's Gallery Visit rokitt51's homepage! Find More Posts by rokitt51
Old 04-06-2008, 2:26 PM
i have two sets of calipers and the other ones didn't work either. Fluid flows in a stead stream everywhere. There is just no pressure.
mab5155 is offline
Old 06-14-2008, 7:40 AM
Bike(s): GL1100 Standard
Rep: netphish is on a distinguished road (10)
All, I have the same exact problem on my 1980 Goldwing. I purchased all new stainless brake lines and a whole new modern master cylinder brake assembly from Ebay. Installed and bled the system throughly but still no brakes!
The manual says to put a small block behind the brake lever when bleeding. I didn't do this, could that be the prob???? If so, what is the easiest way to fix.
I need to get this fixed so I can get back on the saddle and cruise!
netphish is offline
View netphish's Profile View netphish's Gallery Find More Posts by netphish
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 11:32 AM.
