2008 Suzuki GSX-R1000 K8 Photos and Specifications
Old 06-26-2008, 5:05 PM
I'm a bird.. NOT a bloke!!!
LoopyLee's Avatar
Bike(s): CBR400RRN, and a bike in bits
Rep: LoopyLee will become famous soon enough (72)
The new 2008 Suzuki GSX-R gets a new look with more effective aerodynamics and a new fairing with three horizontally mounted halogen headlights. Main beam uses all three lights, with a 'position lamp' above the main headlight to keep the traditional vertically stacked look of the Suzuki GSX-R. There is a larger 17.5-litre tank to provide fuel for the 13,750rpm redline engine, which features three engine maps selectable on-the-fly. It has a new Suzuki fuel injection system, and is housed in an aluminium-alloy frame, with a new rear sub-frame, which saves 125 grams. There are fully adjustable Showa forks and rear shock, 14-position adjustable foot pegs, an electronic steering damper that reacts to the speed of the motorcycle, and a seat height of 810mm.
The lighter alloy wheels are the same dimensions as the previous Suzuki, but save 430 grams between them. The front brakes are dual radial-mount opposed Tokico front callipers with 310mm discs. The single-piston rear Tokico calliper works with a 220mm disc.
Features
Compact fuel injection system features the Suzuki Dual Throttle Valve System (SDTV) - Idle Speed Control (ISC) system for improved cold starting, consistent idle quality and reduced emissions
High volume Suzuki Advanced Exhaust System (SAES)
The mid-pipe includes a Suzuki Exhaust Tuning (SET) system for maximum torque throughout the rpm range and an oxygen sensor used by the engine management system and combined with the under-engine catalyser for reduced emissions
S-DMS (Suzuki-Drive Mode Selector) system allows the rider to choose from three engine settings to match track conditions with a handlebar-mounted switch
Electronically controlled steering damper uses a solenoid valve to move a tapered needle reducing or increasing oil flow to adjust damping force.
An easy-to-read instrument cluster includes a step motor controlled analogue tachometer, digital LCD speedometer, dual tripmeters, clock, convenient gear position sensor, rpm indicator light and a new LCD S-DMS mode indicator displaying which performance setting has been selected by the rider
Specifications
Specs Engine: 4-stroke, liquid-cooled, DOHC
Bore Stroke: 73.4 x 59.0mm
Compression Ratio: 12.5 : 1
Fuel System: Fuel injection
Lubrication: Wet sump
Cooling System: Liquid
Ignition: Electronic ignition (Transistorised)
Transmission: Close ratio, 6-speed constant mesh
Final Drive: D.I.D 530, 112 links
Suspension Front: Inverted telescopic, coil spring, oil damped
Suspension Rear: Link type, coil spring, oil damped
Brakes Front: Disc brake, twin
Brakes Rear: Disc brake Tires Front: 120/70ZR17M/C (58W), tubeless
Tires Rear: 190/50ZR17M/C (73W), tubeless
Fuel Tank Capacity: 17.5 L (4.6/3.8 US/Imp gal)
Overall Length: 2045 mm (80.5 in)
Overall Width: 720 mm (28.3 in)
Overall Height: 1130 mm (44.5in)
Seat Height: 810 mm (31.9 in)
Ground Clearance: 130 mm (5.1 in)
Wheelbase: 1415 mm (55.7 in)
Dry Weight: 172 kg (379 lbs)
Colours: Blue/White, Black/Gold, White/Silver, Matt Black
ID:	30312  Click image for larger version
ID:	30313  Click image for larger version
ID:	30314  Click image for larger version
Sh*t happens, deal with it and move on..
LoopyLee is offline
View LoopyLee's Profile View LoopyLee's Gallery Find More Posts by LoopyLee
Old 06-26-2008, 5:32 PM
Maholli's Avatar
Bike(s): 2008CBR1000RR, 2007 CBR 1000RR, 2006 VTX1300C
Rep: Maholli will become famous soon enough (65)
Re: 2008 Suzuki GSX-R1000 K8 Photos and Specifications
Great job loopy but im confused about the [quote][16,000rpm redline engine/QUOTE]? I thought it was 13,750..
2008 Suzuki GSXR-1000: Suzuki's Latest Literbike Boasts Tons of New Technology ... which eventually terminates with a stratospheric redline of 13750 rpm. ...
Maholli is offline
Old 06-27-2008, 2:25 PM
LoopyLee's Avatar
Have corrected offending number after peering at K8 clocks on youtube..
LoopyLee is offline
Old 06-27-2008, 6:40 PM
Maholli's Avatar
I wasn't sure either way.. Great job...
Maholli is offline
Old 06-27-2008, 6:53 PM
Website Owner - AYS
.OrgOwner's Avatar
Rep: .OrgOwner will become famous soon enough (77)
Nice work Loopy!
"Making it to the summit is optional. Making it back to basecamp is not."
.OrgOwner is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 9:13 AM.
