Cold starting problem
Old 02-10-2009, 2:42 PM
Bike(s): suzuki gs1100e Honda CB900F Kawasaki Gpz1100
Rep: coffeeman is on a distinguished road (10)
I have a 1978 gs750 that takes forever to start when cold once its warmed up no problem. I dont know where to start to fix.
coffeeman is offline
View coffeeman's Profile View coffeeman's Gallery Find More Posts by coffeeman
Old 02-11-2009, 4:04 AM
Bike(s): CBR929, 3xGSXR750, GSXR1000, ZX6R, XS250, KZ750
Rep: bladeracer has much to be proud ofbladeracer has much to be proud ofbladeracer has much to be proud ofbladeracer has much to be proud ofbladeracer has much to be proud ofbladeracer has much to be proud ofbladeracer has much to be proud ofbladeracer has much to be proud ofbladeracer has much to be proud of (1182)
Re: Cold starting problem
Are you using the choke circuit?
View bladeracer's Profile View bladeracer's Gallery Visit bladeracer's homepage! Find More Posts by bladeracer My Map Location
Old 02-11-2009, 7:38 AM
Yes i use the choke and it is in working conduction. If i turn choke off to soon the bike will stall. Throttle response is also poor when cold.
Old 02-11-2009, 7:49 AM
Stalling and poor response is normal for a cold engine without the choke (because the fuel tends to bead on the cold metal of the intake tracts instead of atomising with the air and thus is way too lean for combustion).
It shouldn't need any throttle at start up with the choke engaged. Opening the throttle will lean it off even further.
How long has it been playing up?
Old 02-11-2009, 8:47 AM
I just got the bike in Nov the seller said its been happing all of fall. Even with out the throttle it takes 7 or 8 long attempts to the point of almost killing the battery. Also no smell of gas during starting attempts.
Old 02-11-2009, 9:01 AM
If it's been sitting for some time, the idle and choke circuits of the carbs may be clogged up. If you can reach the airbox intake you could try blocking most of it off with your hand and see if that helps. It's much more likely that it's starving for fuel (assuming the carb circuits are blocked) but less air might improve the mixture enough to start it, although it really would need more fuel.
It quite likely could use fresh plugs as well.
Old 02-11-2009, 9:12 AM
I will try all that you said and and see what happens. Thanks for the info.
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 3:46 PM.
