Go Back   Honda Motorcycles - FireBlades.org Forums > General Motorcycling > Tools / Garage / Paddock
Pit bull front stand
Old 09-22-2005, 10:06 PM
Bike(s): 1994 900RR
Rep: jc1litr is on a distinguished road (10)
Hello, I have a 94 900RR with a 99 upper fairing and 97 forks and triple clamp. I'am having trouble getting my front stand to lift the bike without hitting the lower part of the fairing. Iam using the pin that pit-bull says works with the 94-97,also I called them to ask about the newer fairing and they said that wouldn't matter? The rear of the upper bar of the stand hits right below the front air intake. Am I doing something wrong? (Sorry for the LOOONG post)
jc1litr is offline
View jc1litr's Profile View jc1litr's Gallery Find More Posts by jc1litr
Old 09-22-2005, 10:08 PM
ND4SPD's Avatar
Bike(s): '84 Magna V30
Re: Pit bull front stand
Are your forks in the stock position or is the bike lowered?
ND4SPD is offline
Old 09-22-2005, 10:17 PM
Bike(s): 1994 900RR
The forks are flush with the clamps. This means it's not lower,correct?
jc1litr is offline
Old 09-22-2005, 10:19 PM
ND4SPD's Avatar
As in the top of the fork tubes are flush with the triple?
ND4SPD is offline
Old 09-22-2005, 10:24 PM
Bike(s): 1994 900RR
Yes they're flush with the triple clamps,just rebuilt stock last year. (Duh)
jc1litr is offline
Old 09-22-2005, 10:28 PM
ND4SPD's Avatar
To me that sounds like it's a bit too high. Although that could be how the '94s were made. Then again it could have zero effect on your issue as well.
ND4SPD is offline
Old 09-22-2005, 10:34 PM
Bike(s): 1994 900RR
I guess maybe the answer is to call pitbull and order the parts to convert my stand to a fork lift style. Thanks for the help though. (If you ever travel south look me up, not too many sport bikes around here mostly Hardleys)
jc1litr is offline
Old 09-22-2005, 10:36 PM
Bike(s): 04 R6
Rep: Scratch is on a distinguished road (47)
Is it a pitbull "new" front stand or the old style? Not sure on the old style but the "new" front has some height adjustments you can make. Had to expirement with mine to get it just right for the Jiggy.
Scratch is offline
View Scratch's Profile View Scratch's Gallery Find More Posts by Scratch
Old 09-22-2005, 10:57 PM
Bike(s): 1994 900RR
Scratch, it's the new style. I have messed with the adjusters with no luck. I take off the front fender,insert the pin. Press up on the stand and down on the handle. Smack right into the fairing every time. It has a little crack now that you can't see unless you press up or use the stand.
What is really funny is I used the thing on my buddies old 02 daytona 955i, worked like a champ!!!
jc1litr is offline
Old 09-22-2005, 11:05 PM
Bike(s): 04 R6
Sorry to hear that, wish there was something I could do to help you out. I take it the pin is inserted correctly and all that? You shouldn't have to remove the fender to use the stand either... Can you loosen the upper a bit, put a rag/towel on the part of the stand where it hits the upper and lift it that way w/o causing any more damage?
Scratch is offline
Old 09-23-2005, 11:05 PM
Bike(s): red '04 1000RR
Rep: garbau is on a distinguished road (10)
Some of the pins have a slight bend/angle in them, not noticeable at first glance. You may have the pin in backwards.
garbau is offline
View garbau's Profile View garbau's Gallery Find More Posts by garbau
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 2:13 PM.
