Go Back   Honda Motorcycles - FireBlades.org Forums > General Motorcycling > Tools / Garage / Paddock
Solution for the cooling problems of the 954
Old 02-22-2007, 8:41 PM
  #31
Bike(s): Working on it.
Rep: Gigolo Jason is on a distinguished road (32)
Re: Solution for the cooling problems of the 954
Originally Posted by tdeal28 View Post
It seems that theres a miss conception about boiling point of water/antifreeze. Water boils at 212 deg F.
Two things increase the boiling point of water:
1. By adding ethylene glycol (Antifreeze) to the water
2. Pressurizing the water/coolant within a sealed system
This is correct. The boiling point of a stock system on a 15psi cap with a 50/50 mix is somewhere around 263F.
Cutting the cap on a stock system will only result in an overheated bike.
By running a 0psi radiator cap you are actually keeping the boiling point of water or water/antifreeze mix at the normal boiling point. By pressuizing the sytem you are raising the boiling point. Thats way ALL vehicles and motorcycles come with pressure caps.
If you are directing this comment to me then you have misread my post. I do not run a water based coolant system in my 954. I run a waterless oil based propylene glycol coolant which boils at 375F without pressurization. I now have a little over 2K miles on the clock while running Evans at 0psi.
Gigolo Jason is offline
View Gigolo Jason's Profile View Gigolo Jason's Gallery Find More Posts by Gigolo Jason
Old 03-14-2007, 12:57 AM
  #32
Bike(s): 02 954 06 600rr
Rep: Firehawk is on a distinguished road (10)
has anyone tried a supplemental fan or changing the fan temp sensor to activate the fan at a lower temp?
Firehawk is offline
View Firehawk's Profile View Firehawk's Gallery Find More Posts by Firehawk
Old 03-14-2007, 10:23 AM
  #33
Bike(s): 2003 CBR954rr
Rep: steingar will become famous soon enoughsteingar will become famous soon enough (145)
There seems to be a misconception about how engines run. They breath air. In many parts of the world air has water in it. We call that humidity. That water can condense and corrode engine parts from the inside. Thus 220 degrees is a damn good temperature at which to run your engine.
Airplanes have aluminum engines. I actually have to block off the oil induction system on my Cherokee in cold weather to keep the oil temperature up around 220 degrees.
steingar is offline
View steingar's Profile View steingar's Gallery Find More Posts by steingar
Old 03-15-2007, 1:01 AM
  #34
after two blown head gaskets, i'd tend to differ in my opinion.
Firehawk is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 8:21 PM.
