Go Back   Honda Motorcycles - FireBlades.org Forums > General Motorcycling > Tools / Garage / Paddock
Front Brakes Master Cylinder
Old 06-14-2008, 10:44 AM
Bike(s): GL1100 Standard
Rep: netphish is on a distinguished road (10)
I purchased all new stainless brake lines and a whole new modern aftermarket master cylinder brake assembly. Installed and bled the system throughly but still no brakes! During the bleeding process I was unable to build pressure buy pumping the brake with the caliper nipple valve closed. The piston in the master cylinder could be cavetating...but it's brand new!
The manual says to put a small block behind the brake lever when bleeding. I didn't do this, could that be the prob???? If so, what is the easiest way to fix.
I need to get this fixed so I can get back on the saddle and cruise!
netphish is offline
View netphish's Profile View netphish's Gallery Find More Posts by netphish
Old 06-14-2008, 10:59 AM
Red Rider's Avatar
Bike(s): '01 CBR929
Rep: Red Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to behold (819)
Re: Front Brakes Master Cylinder
If the new lines are filled and you're using the correct bleeding procedure, than I would suspect the aftermarket M/C.
Red Rider is offline
Old 06-14-2008, 3:22 PM
Hmm, guess I don't have much choice but to pull it off and inspect.
netphish is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 4:56 AM.
