04-15-2004, 3:09 PM
| Hauling in the bed... Anybody take a piece of plywood, cut it to the shape of the bed and put a wheelchock down and secure the bike that way instead of just plain ol' strapping the bike in? |
04-15-2004, 3:35 PM
Bike(s): R/B 929, SV650 (race) Posts: 1,838
Rep:   (114) Rep Power: 9
| Re: Hauling in the bed... Quote: |
Originally Posted by ND4SPD Anybody take a piece of plywood, cut it to the shape of the bed and put a wheelchock down and secure the bike that way instead of just plain ol' strapping the bike in? | Yep, but you only need enough plywood to get around the wheel well, no need to buy a piece that fits the entire bed.
-Shrub |
04-15-2004, 3:37 PM
| Re: Hauling in the bed... That's enough to keep the bike secure? I figured just buying a whole sheet would be better  |
04-15-2004, 3:52 PM
Bike(s): '06 CBR1000RR, '06 CRF450X, '06 CRF100 Posts: 5,998
| Re: Hauling in the bed... You only have to use enough of plywood to ensure that it, the plywood base, will not slide in any direction.
04-15-2004, 4:04 PM
Bike(s): what's next? Posts: 1,814
Rep:   (116) Rep Power: 10
Originally Posted by Pete You only have to use enough of plywood to ensure that it, the plywood base, will not slide in any direction. | If the wood is as wide as the bed, it only needs to be as long as the chock (if it's up against the front of the bed). That way, with the bike strapped in place, the chock can't move. |
04-15-2004, 5:59 PM
Originally Posted by Serial Thriller If the wood is as wide as the bed, it only needs to be as long as the chock (if it's up against the front of the bed). That way, with the bike strapped in place, the chock can't move. | Then based on your logic, the plywood only needs to be marginally wider than the chock as well.
To be honest, the more I think about it, the more I like the idea of a full sheet covering the entire bed. so that the chock is attached to something that is bound by the entire weight of the bike. Then again, I tend to overbuild everything. |
04-15-2004, 6:28 PM
Originally Posted by Pete Then based on your logic, the plywood only needs to be marginally wider than the chock as well.
To be honest, the more I think about it, the more I like the idea of a full sheet covering the entire bed. so that the chock is attached to something that is bound by the entire weight of the bike. Then again, I tend to overbuild everything. | Pete = the Toolman? |
04-15-2004, 6:55 PM
Bike(s): 929, EX250rrr Age: 44 Posts: 1,666
Rep:   (107) Rep Power: 9
| Re: Hauling in the bed... Why not just bolt the chock into the bed?  |
04-15-2004, 6:58 PM
Rep:   (137) Rep Power: 14
Originally Posted by dB Why not just bolt the chock into the bed?  | A good friend of mine in Dallas did that. He has a very nice chock bolted down in the bed, spray liner underneath it. I dunno how he did it but it works rather well. |
04-15-2004, 7:50 PM
Bike(s): 2002 954 - sold - Now riding a 2005 GSX-R750 Posts: 63
Rep:  (44) Rep Power: 7
Originally Posted by booth23 A good friend of mine in Dallas did that. He has a very nice chock bolted down in the bed, spray liner underneath it. I dunno how he did it but it works rather well. | It is a little more expensive, but you can get a "LA sport chock" for $200.00, and secure the bike frame to the forward tie downs (no need to compress the forks). No need to bolt the sport chock down. |
04-15-2004, 8:59 PM
Originally Posted by dB Why not just bolt the chock into the bed?  | Truck is a lease, I don't want to modify anything I can't undo. |
04-15-2004, 11:12 PM
Bike(s): 99 CBR1100XX (Street), 01 CBR1000RR (Track) Age: 41 Posts: 1,524
Rep:  (43) Rep Power: 7
Originally Posted by ND4SPD Truck is a lease, I don't want to modify anything I can't undo. | I did this...... It just drops in the places that are normally used to make a 2nd level for carrying sheets of plywood. |
04-23-2004, 1:03 PM
#13 |
Bike(s): 02 954 sil/blk-gone 01 FZ1 Age: 50 Posts: 705
Rep:  (11) Rep Power: 6
| Re: Hauling in the bed... The only problem with useing wood; if it gets wet/soaked it'll warp and you'll probably have to redo it. |
04-23-2004, 1:10 PM
#14 |
Bike(s): Black/Red 929RR (Sold) Posts: 1,900
Rep:   (140) Rep Power: 9
| Re: Hauling in the bed... I cut an entire sheet of plywood to fit the bed. I didn't need a wheel chock since the tailgate just closed (short bed). Which reminds me, Pitbull charged me a repolishing fee when I returned the wheel chock, after setting the wheel chock on the floor ONE time ($17 freaking dollars). But I digress, like someone stated the boards did get warped after a full summer. |
04-23-2004, 2:08 PM
#15 |
Originally Posted by Pete Then based on your logic, the plywood only needs to be marginally wider than the chock as well. | I'm not sure I follow you.  I meant the wood the chock is bolted to would be the width of the bed so it couldn't move laterally. |
04-23-2004, 2:19 PM
#16 |
Originally Posted by slowpoke The only problem with useing wood; if it gets wet/soaked it'll warp and you'll probably have to redo it. | The wood I posted in the pic is 5 years old. |
04-23-2004, 2:43 PM
#17 |
Originally Posted by Serial Thriller I'm not sure I follow you.  I meant the wood the chock is bolted to would be the width of the bed so it couldn't move laterally. | Yeah, I understood what you meant. What I meant is that with the bike strapped in, the chock has about the same chance moving to one side or the other as it does moving to the rear.
All the way or nothing, that's my motto.  |
04-23-2004, 3:56 PM
#18 |
Originally Posted by CBRBob The wood I posted in the pic is 5 years old. | I sit corrected!  How many times has it been soaked though? |
04-23-2004, 4:35 PM
#19 |
Originally Posted by Pete All the way or nothing, that's my motto.  |  By the way, that explains a lot... |
04-23-2004, 8:42 PM
#20 |
Originally Posted by slowpoke I sit corrected!  How many times has it been soaked though? | Almost every other time I have gone somewhere unfortunately. It's not even pressure treated. |
04-24-2004, 1:25 AM
#21 |
Bike(s): Addicted to them. Posts: 4,302
| Re: Hauling in the bed... I built a chock wide enough to fit between my wheel wells and the length of the bed (tailgate up). Reason for doing this was twofold, #1 - I was going to leave the chock setup in the bed sans bike, and didn't feel like having it slide all around. #2 - have heard nightmares of folks crank their bike down too much and dent the ribbing in their bed.
I built the chock out of 2x4's on their side, one for the front tire one for the rear, the front also had (2) mitre cut pieces aiding in some vertical support as well. I made it with a piece of 5/8" stock ripped down the middle and placed right behind the front "chock" area. I had it setup so I could roll the bike right up into the bed and w/o kickstand it would stay there on its own even under a bit of grade. This was ONLY so I could get off it and tie it down alone w/o having to hop back and forth 40 times to sync. each tiedown.
Sold the 929/954 but I have the same deal with my YZ450 and its fly.
Just to clarify - you're using tie downs yes? this isnt you just wanting to use plywood and a wheel chock to secure the ride, just to clarify.
Also AncraŽ gets my vote if you want a hassle-free moving experience, the black ones for some reason last longer, don't ask me why tho... |
04-24-2004, 1:37 PM
#22 |
| Re: Hauling in the bed... btw - mine isn't PT either, and its about 4 years old, just use decent hardware so the chit don't rust out  |
05-04-2004, 6:09 PM
#23 |
Join Date: 11-27-2001 Location: Virginia Beach, Va. grew up in Latrobe PA.
Bike(s): CBR1000RR Age: 33 Posts: 91
Rep:  (10) Rep Power: 7
| Re: Hauling in the bed... if you strap it down right, you don't need a chock. |
05-05-2004, 12:03 AM
#24 |
Originally Posted by soniccbr if you strap it down right, you don't need a chock. | True. Its just that whopping 7$ in lumber adds alot to the surety of things, why wouldn't you?  |
05-05-2004, 9:31 AM
#25 |
| Re: Hauling in the bed... +1 Besides, I have a bedlines, the tire wants to slip all the time. |
05-08-2004, 10:08 PM
#26 |
Bike(s): Bikeless Posts: 8,830
Originally Posted by john954rr It is a little more expensive, but you can get a "LA sport chock" for $200.00, and secure the bike frame to the forward tie downs (no need to compress the forks). No need to bolt the sport chock down. | Wow, look at this thing. Trick! LINK
This is a timely thread. I was just about to post a query on a creative way to mount a Pit Bull chock in my Chevy's bed, but I'll do it here.
So, how?
My truck has a thick, sprayed on Rhino Lining bed liner which I don't mind drilling into to mount one of these... http://www.dallasmotorcycles.com/la_...portschock.htm
...but it'd be great to rig it for easy removal. Threaded bosses sunk below the bed surface? Or maybe bolt the bastard in and call it a day. Problem with that is obvious - you take up room in your bed when not hauling the bike.
Whatcha guys think?
Edit: I like the recessed mouting hardware with that LA Sport Chock. Doggoneit though, the chock and hardware makes for an expensive little gadget.
05-08-2004, 10:21 PM
#27 | | Mr. Brownstone
