6X12 and 7X14 pics please.
Old 11-01-2004, 9:11 PM
  #121
Baketech's Avatar
Re: 6X12 and 7X14 pics please.
Yes, they work fine for me....but I understand there are a lot of folks that don't like them....but that's cool too....
Sorry...don't want to jack your thread....
Sith Apprentice
Baketech is offline
Old 11-02-2004, 9:25 AM
  #122
showmethebombs's Avatar
Bike(s): none again...so far...
Rep: showmethebombs will become famous soon enough (87)
no, your on topic. I have a CD too...but I was not sure how it would work with the Ohlins damper. I will have to screw around with it and see.
showmethebombs is offline
View showmethebombs's Profile View showmethebombs's Gallery Find More Posts by showmethebombs
Old 11-02-2004, 9:36 AM
  #123
Baketech's Avatar
Not sure how it will work with the Ohlins...I have a Scott's...
I was only hesitant to bring it up because CD's are on the official "thread vortex" list....lots of opinions and anecdotes both pro and con...
Sith Apprentice
Baketech is offline
Old 11-02-2004, 9:37 AM
  #124
ConqSoft's Avatar
Bike(s): 2007 Honda ST1300
Yep, they work with Scotts and Ohlins. I used a CD with each at one point or another...
ConqSoft is offline
Old 11-02-2004, 9:55 AM
  #125
Nice! thanks for your help guys! I cannot wait to go to the track this time.
Old 11-02-2004, 10:09 AM
  #126
Bike(s): none
Rep: figment will become famous soon enough (64)
Send a message via MSN to figment
Originally Posted by Baketech
I'm not CD-phobic....I think they work fine....ymmv...
I do too, and I still pull them from the front of the bike.
figment is offline
View figment's Profile View figment's Gallery Visit figment's homepage! Find More Posts by figment
Old 11-02-2004, 10:14 AM
  #127
ConqSoft's Avatar
Yep. But, if you run 8ft of e-track, you're fine. (The 'blade is ~6ft long, so that gives you ~2ft out front for the tie downs.)
ConqSoft is offline
Old 11-02-2004, 10:16 AM
  #128
Bike(s): none
you want the trailer load proportioned. Put the ENGINE just for of the axles whatever that relates to in positioning the chocs. TRUE, Etrak gives you that flexiibility.
figment is offline
Old 11-02-2004, 10:18 AM
  #129
Bike(s): none
and I have 5 runs of etrack
figment is offline
Old 11-02-2004, 10:20 AM
  #130
ConqSoft's Avatar
On my 6x12, putting the bikes all the way at the back, and gear up front, it was well balanced. Different trailers may have the axles located in different positions, however.
I think the manual for my trailer said that you want 60% of the load in front of the axle, and 40% behind.
ConqSoft is offline
Old 11-02-2004, 10:21 AM
  #131
Bike(s): none
thats the GENERAL rule if thumb. you can use a scale to see if you have the correct weight on the tongue.
figment is offline
Old 11-02-2004, 10:36 AM
  #132
Baketech's Avatar
Been down this road before....
To each his own...I run 4 straps all forward. The rears are just for safety on rough roads, as the front 2 are enough...
Sith Apprentice
Baketech is offline
Old 11-02-2004, 11:02 AM
  #133
Bike(s): none
so have I and I dropped two bikes that way
now the rear pulls to the rear to keep the front ties TIGHT and preventing them from slacking off.
figment is offline
Old 11-02-2004, 11:04 AM
  #134
ConqSoft's Avatar
If you use racheting straps on the front, and compress the forks about 50%, you'll be fine. I pulled my XX over 3000 miles (out to the midwest and back) with no problems. (Not to mention all the gap trips flasher and I made.)
ConqSoft is offline
Old 11-02-2004, 11:08 AM
  #135
Baketech's Avatar
I've never dropped a bike....so I have no direct anecdote for that...
To each his own...more than one way to skin a cat...
Sith Apprentice
Baketech is offline
Old 11-02-2004, 11:12 AM
  #136
Bike(s): none
My front straps are about 2 feet ahead and to the side of the bars and in front of the plane of the front wheel. On the last trip to AR, I stopped to check my new ratcheting straps on the front @ about 100 miles. THEY WERE LOOSE. So I INCREASED the angle on the rear straps to MORE rearward (1 foot behind the bike, and the front straps held the rest of the 500 miles 100%.
figment is offline
Old 11-02-2004, 11:14 AM
  #137
ConqSoft's Avatar
Where's the vortex pic?
ConqSoft is offline
Old 11-02-2004, 11:15 AM
  #138
Mr. Brownstone
Bike(s): 05 600RR
Just buy a Sport Chock, put it anywhere in your trailer you want and use two tie downs, just snug, on the back - pulling forward. Much better on the forks, and no chance of dropping the bike. Unless you're a moron.
BDA116 is offline
Old 11-02-2004, 11:16 AM
  #139
Bike(s): none
I still don't understand where your tie-point is on the floor of the trailer with the choc all the way to the front
Are your front straps at right angles to the bike?
figment is offline
Old 11-02-2004, 11:17 AM
  #140
Baketech's Avatar
It's warming up on "Ready 5"....
Sith Apprentice
Baketech is offline
  #141
ConqSoft's Avatar
Even with the chock all the way to the front, you still have some forward area. The bars are behind the front wheel.
ConqSoft is offline
Old 11-02-2004, 11:18 AM
  #142
ConqSoft's Avatar
Why not just buy an R1? It's the pefect bike for towing. Needs no chocks or tie downs. It just stands on its own.
ConqSoft is offline
Old 11-02-2004, 11:19 AM
  #143
Baketech's Avatar
Nope, they are angled well ahead of the forks...
Sith Apprentice
Baketech is offline
Old 11-02-2004, 11:20 AM
  #144
Baketech's Avatar
