2000 GMC Sierra Trailer wiring
01-27-2005, 11:36 PM
#1 | | Going into turn one
Bike(s): '04 CBR1000RR, '84 Ascot, '02 RC51 Posts: 13,849
| 2000 GMC Sierra Trailer wiring OK so I have a six wire and need to go seven to the new trailer. I have a brake controller plug under the dash and a six wire harness to the back. Is it possible to replace the 6 wire with a 7 wire from the dealer or is this a major mistake to even think about?
Thanks
Send maple |
01-28-2005, 12:56 AM
Bike(s): Addicted to them. Posts: 4,302
| Re: 2000 GMC Sierra Trailer wiring edit: nevermind.
what kind of trailer is it? does it have interior utilities that require the 7th wire or is that just how it came?
edit2: Click Me if you don't mind a trip to walmart. actually link is weird, reference part ## R74645
01-28-2005, 1:15 AM
#3 | | Going into turn one
| Re: 2000 GMC Sierra Trailer wiring Quote: |
edit2: Click Me if you don't mind a trip to walmart. actually link is weird, reference part ## R74645 | The trailer comes with 7 wires, I will know more when I look at the docs and get the meter out etc. So I would need a 6 to 7 (not seen one yet). However I think the seventh wire is for charging the brake battery and maybe lights. The truck comes stock with a 6 wire harness to the back however there is an option of 7. I thought there is a chance that it is wired and I just need to get the other harness from GMC.
Anyway I am figuring it out and thought a site member might have a similar setup since Chevy's and GMCs (after 2000 I think) are the same setup and lots of folks probably have trailers for bikes or camping here
Send maple |
01-28-2005, 2:18 AM
Bike(s): BMW R1150GS ADV and down to only 4 others! Posts: 3,203
| Re: 2000 GMC Sierra Trailer wiring 6 wire to the back??? I'm not familiar with GMC wiring...usualy vehicles have a standarf 4 prong, or the 7 prong. The 7 prong just adds a 12v for battery charging (8-10 gauge black), a blue for trailer brakes, and a orange for backup lights. If you already got brake controller harness in the cab, it usualy has 4 wires.
01-28-2005, 2:21 AM
| Re: 2000 GMC Sierra Trailer wiring Check this out http://www.etrailer.com/faq/wiring.asp
sounds like you need to run a 12v wire fronthe battery to the rear of your truck. There are wiring diagrams for this on the 'net, I'll see if I can find it. Use a 8 or 10 ga wire. |
01-28-2005, 2:24 AM
| Re: 2000 GMC Sierra Trailer wiring ...actualy, it appears the 6 wire would work, its only missing the auxlurity wire...what is typicaly used for back up lights. But considering 99% of trailers (unless we are talking boat trailers) with electric brakes have 7 pin, I would convert yours. It should only take rewiring at the bumper and tapping into the reverse lights wire. |
01-28-2005, 3:28 AM
Originally Posted by sheepofblue So I would need a 6 to 7 (not seen one yet). However I think the seventh wire is for charging the brake battery and maybe lights. |  did you click the link above? |
01-28-2005, 6:01 AM
| Re: 2000 GMC Sierra Trailer wiring Congrats on the trailer. Can't help ya with the wiring, the trailer place installed mine since I only had 4 pin, and did the brake controller too. I've only seen 4 and 7 pin. 6, huh. Good luck with it!  |
01-28-2005, 9:07 AM
#9 | | Going into turn one
| Re: 2000 GMC Sierra Trailer wiring I looked and while mine is a six and I have 6 in the harness I only use 4 right now. Looks like it is time to string wire  Etrailer also had info on my truck specific but I was hoping to swap a harness rather than string wire for slickness of install
Send maple |
01-28-2005, 10:14 PM
Originally Posted by sheepofblue I looked and while mine is a six and I have 6 in the harness I only use 4 right now. Looks like it is time to string wire  Etrailer also had info on my truck specific but I was hoping to swap a harness rather than string wire for slickness of install  | what the hell am I missing?? I've done just about anything you can do electrically to a car and I'm still confused  . Can you draw a diagram  |
01-28-2005, 10:30 PM
#11 | | Going into turn one
Originally Posted by SomeStrangeGuy what the hell am I missing?? I've done just about anything you can do electrically to a car and I'm still confused  . Can you draw a diagram  | It is confusing. 2000 GMCs came two ways, with tow package and w/o
The 'with' is a 7 pole connector wired complete just plug a brake controller in and go.
The without (aka mine) has wiring exposed above the spare tire with 6 wires although i have found out 2 of the 6 are for weird things. This is easily connected to a 4 pole system. Also the truck is wired to accept a controller in the cab. What I wanted was to get the OEM 'with' wiring harness and plug it into my truck. Thus I would have a poor man's tow package (I already have the hitch reciever). However I have been told by the dealer that although the cab is wired for a brake controller the existing wiring is not able to have the HD tow package harness added. I am going to look at my truck an the Helm's Manual a bit more but figure I will have to drag some wire to the back from the fuse box.
Send maple
01-28-2005, 11:31 PM
Originally Posted by sheepofblue It is confusing....I am going to look at my truck an the Helm's Manual a bit more but figure I will have to drag some wire to the back from the fuse box. | I gotcha now I think, and I think you may be missing the fuses and terminals that the HD has. But yeah you're on the right track, as the primary diff between 6/7 wires is that the 7 has an extra 'power' wire to run onboard aux. equipment. From what I can recall this is usually rated no less then 20a.
BillAce may have more experience with this then I, but then again the question is not a complex orchestration of thiele-small params. rather simple 12vdc with current limiting.
Did I ask what kind of trailer yet?
...and in the end I highly recommend sourcing an all out re-kit rather the just adding some conductors to the existing. Just cleaner and neater, and since the labor is the same price  |
01-28-2005, 11:42 PM
#13 | | Going into turn one
Originally Posted by SomeStrangeGuy I gotcha now I think, and I think you may be missing the fuses and terminals that the HD has. But yeah you're on the right track, as the primary diff between 6/7 wires is that the 7 has an extra 'power' wire to run onboard aux. equipment. From what I can recall this is usually rated no less then 20a.
...and in the end I highly recommend sourcing an all out re-kit rather the just adding some conductors to the existing. Just cleaner and neater, and since the labor is the same price  | That is why I wanted the whole harness, about $90 but it would have been cleaner and more reliable. I have a link at etrailer.com with instructions but it is not as clean.
The trailer is a Shadowmaster and if the ice storm doesn't screw the roads over to bad I will have pics tommorow
Send maple |
02-27-2005, 12:19 AM
#14 | | Going into turn one
| Re: 2000 GMC Sierra Trailer wiring Update: My harness came in. Not only will it hook into the existing wiring and fuse box it comes with some fairly detailed instructions. Anyone that is looking to wire up a GMC/Chevy from 2000 up should consider this route.
Send maple |
02-27-2005, 1:56 PM
#15 |
Originally Posted by G-Force Junkie ...actualy, it appears the 6 wire would work, its only missing the auxlurity wire...what is typicaly used for back up lights. But considering 99% of trailers (unless we are talking boat trailers) with electric brakes have 7 pin, I would convert yours. It should only take rewiring at the bumper and tapping into the reverse lights wire. | The aux wire is also used for interior lights on enclosed trailers. |
