Go Back   Honda Motorcycles - FireBlades.org Forums > Events > Track Days / Riding Schools
bike setup for track day..
Old 11-05-2006, 8:38 PM
Bike(s): 954
Rep: anthmac is on a distinguished road (10)
hi all,
getting ready for my first track day. well superbike school but you get some laps afterwards. and yeh wanting to know if there is anything i should adjust on my bike ot make it a smoother experience. dunno much about bike setups or anything but often hear of talk regarding suspension changes and sprocket changes etc. if anyone could pass some info on what i should be looking at changing beforehand that would be great. btw im 6'2 and 75kgs or 165 pnds. cheers..
anth
anthmac is offline
View anthmac's Profile View anthmac's Gallery Find More Posts by anthmac
Old 11-05-2006, 8:40 PM
abtech's Avatar
Bike(s): 2007 RC51
Re: bike setup for track day..
Originally Posted by anthmac View Post
hi all,
anth
Just nod at the instructors and you'll be fine
abtech is offline
Old 11-05-2006, 9:50 PM
FrenchieR6's Avatar
Bike(s): 04 R6, 04 Vstar classic
Rep: FrenchieR6 is a name known to allFrenchieR6 is a name known to allFrenchieR6 is a name known to allFrenchieR6 is a name known to allFrenchieR6 is a name known to allFrenchieR6 is a name known to all (613)
and have fun
FrenchieR6 is offline
View FrenchieR6's Profile View FrenchieR6's Gallery Find More Posts by FrenchieR6 My Map Location
Old 11-06-2006, 8:26 AM
Nickelii's Avatar
Bike(s): 600RR track bike
Rep: Nickelii has a spectacular aura aboutNickelii has a spectacular aura about (196)
Your weight is probably pretty close as far as the rear goes. The front end is going to be soft if it is completely stock. You should have your sag set before getting to the track, or have someone at the track help you with it. I think that your static sag should be 10mm while rider sag should be 25mm-30mm (these #'s are for front and back). If you pay someone to do it make sure to ask them questions while doing it. Ask them why they are turning this or that and what effect will it have on the bike, this way you can learn and make small adjustments yourself. As far as gearing, if your bike is stock I think it's 16/43? If so, I would go 15/45 at least, stock it's got a really tall 1st gear. Don't forget that air pressure you run on the street will not be the same as the track, remeber to chek that before your first session. Make sure to stay well hydrated and have fun! Hope this helps some.
Nickelii is offline
View Nickelii's Profile View Nickelii's Gallery Find More Posts by Nickelii
Old 11-07-2006, 3:20 PM
Bike(s): 954
cheers
i have no idea what your talking about but ill ask ppl when im there
thanks again
anthmac is offline
Old 11-07-2006, 3:24 PM
Nickelii's Avatar
Static sag is the amount the bike sags on it's own. Lift up on the rear end and take a measurement from the axle to a fixed point (somewhere on the sub frame). Then let the bike settle and measure from the same spot. The difference between these 2 numbers should be 10mm, repeat with the forks. After you have that set, sit on the bike and have someone take the measurement from the same spot. When you sit on it, it should compress between 25mm-30mm, this is the rider sag. 16/43 refers to the amount of teeth on the front (16) and rear (43) sprockets. I reccomended 15/45 as -1/+2 is a pretty common gearing.
Nickelii is offline
Old 11-07-2006, 4:34 PM
A Spaniard in Texas.
onevcs's Avatar
Bike(s): 2005 CBR1000RR, '98 Suzuki DR650SE
Rep: onevcs is a jewel in the roughonevcs is a jewel in the roughonevcs is a jewel in the rough (293)
Set up is important and it does affect how your bike handles, but being smooth and not riding over your limits is a far better and improvement.
Approach the turns following the line as closely as possible (have someone that know the track show you where the line is) and reduce your speed with enough distance to enter the turn in the proper gear and already rolling on the accelerator. It makes the bike much more stable.
Follow the line, be smooth and don't ride over your limit. Mind set is far more important than bike set.
onevcs is offline
View onevcs's Profile View onevcs's Gallery Find More Posts by onevcs My Map Location
Old 11-08-2006, 4:18 PM
Bike(s): 954
ill set the sag if i can at the track and ill worry about sprockets and gearing in the future. uyeh onevcs thats true true. im pretty much all about smoothness as is, hence the 954 purchase over other litre options so the emphasis on the day will defiantely be smoothness into and throughout the corner. i have some idea of the line on phillip island corners due to playing about 70+ hours of the track in motogp on ps2. only track me and my mate play. but yeh its the superbike school im going to so they'll be teaching us all the brake in points and lines and everything before we get a few runs by ourselves. cant wait!@!!
anthmac is offline
Old 11-08-2006, 4:19 PM
Bike(s): 954
oh and thanks for the replies.. definately helpful
anthmac is offline
Old 11-08-2006, 4:29 PM
onevcs's Avatar
Slow going in, fast coming out. Have fun. Ride safe.
onevcs is offline
Old 11-08-2006, 5:01 PM
Nickelii's Avatar
If you are riding Phillip Island your gearing may work very well considering it is a fast track. Us here in the States don't have many fast flowing circuits, hence the reason for the gear changes. I envy you, I would love to ride there.
Nickelii is offline
Old 11-09-2006, 9:06 AM
FrenchieR6's Avatar
Old 11-09-2006, 12:25 PM
onevcs's Avatar
Originally Posted by FrenchieR6 View Post
Smoothness is the secret to success....
onevcs is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 1:07 AM.
