well i ordered the repsol fairing kit off of ebay .. from china .. well you get what you pay for you know..
eBay.co.uk: " NEW " HONDA CBR954RR CBR 954 RR Full Set Fairing (item 230035408867 end time 10-Oct-06 21:15:00 BST)
the plastic is very very brittle, if you try to drill holes in it . make sure you go up in small increments cuase there is not much meat around the holes and you will tear off the plastic
. the paint is ok .. but has lots of clear coat dripps on the edges.
also the molds they use or did use or whatever . all the parts are about 1/8th to a 1/4th to small so you gotta stretch everthing out and hope nothing cracks ( well trying to put on the rear section we had to stretch it out over the parts and WALLA it cracked next to the seat section about 2 inches long and there is a 1/16th inch gap from it not being able to close up
also there is no tabs in the back to mount the rear brake light .. and also there is no tabs at all......it is all plastic plugs that you have to try to stretch the plastic body work into place . then drill a hole in the plug and hope that you can get it all straight ...the headlight doesnt even fit all the way in takes like 3 ppl to hold and pull and drill and put the screws in
....anyways it was a learning experiance and i would rather buy a full fiberglass set next time instead of the way to small,brittle plastic.drippy paint full fairing set from ebay .. ugggg
maybe i got a bad set or something . but be warned ..it is a pain in the ass to get on with out cracking and hope your screws stay in after everything is put together.
i think when all is done ..it will be a cool looking bike about 10 feet away
