Go Back   Honda Motorcycles - FireBlades.org Forums > Other Motorcycle Brands > Yamaha Motorcycles
Yamaha Motorcycles: Discussion of Yamaha Motorcycles.
Audiovox CCS-100 cruise control
Old 05-30-2004, 7:06 PM
2OHOH2's Avatar
Bike(s): 1300,625,600,150
Rep: 2OHOH2 is on a distinguished road (35)
Finally installed the cruise control this weekend. Some of it was a real pain (attaching the CC cable to the throttle body cam), and it did take more time that I thought it would, but the end result is very much worth it. The operation is very smooth, and it all works as advertised.
The general procedure for wiring one up to an FJR1300 is found here: http://www.fjr1300.info/howto/audiovox.html
The wiring is surprisingly easy, and the whole install could be accomplished on almost any bike, provided that room for the sizeable servo unit can be found.
I used a $2.50 Fram fuel filter as a vacuum boost container, inline with the vacuum line hooked to cylinder 4. I also routed all the control pad wiring down the middle front fairing spar, as shown in the pic, and hot-glued the control pad to the clutch reservoir and handlebar, also shown in the pic.
So, $95 or so, and about ten hours later, it's a done deal.
ID:	4345  Click image for larger version
2OHOH2 is offline
View 2OHOH2's Profile View 2OHOH2's Gallery Visit 2OHOH2's homepage! Find More Posts by 2OHOH2
Old 05-30-2004, 10:19 PM
NinerPilot's Avatar
Bike(s): 01 929
Re: Audiovox CCS-100 cruise control
Looks good! I took my uncle's FJR for a spin today and I immediatly thought that it was lacking a cruise control.
Chris
NinerPilot is offline
Old 06-01-2004, 1:58 AM
2OHOH2's Avatar
Thanks Niner
I've had a throttlemeister on it for a while now (transplanted from the 954), but it simply doesn't have the functionality of the real deal. CC should be standard on these bikes, but then so should a long list of other farkles. At least adding one isn't expensive.
2OHOH2 is offline
Old 04-03-2009, 4:34 PM
Rep: Excell is on a distinguished road (10)
I have two questions for you .First there is a grey wire coming out of the switch assembly .Do you know what it is for? Second did you use the speed sensor ?
Excell is offline
View Excell's Profile View Excell's Gallery Find More Posts by Excell
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 9:50 AM.
