Yamaha Motorcycles: Discussion of Yamaha Motorcycles.
01-07-2006, 3:18 AM
Bike(s): turbo Posts: 116
Rep:  (46) Rep Power: 4
| R6 drifting yesterday I took a spin on my brother's 05 R6.
Now I've been riding the 954 for quite sometime, which has much more power than the R6, but this has never happened to me! I'm headed into a 90-degree right hander at about 20mph, it has a long straight after it, so I get on the throttle about the peak of the turn. Next thing I know, the back end is sliding out to my left. Fortunately it corrected promptly, but it was enough to send my balls up into my stomach.
I tried it again at a lower speed and in first gear and I got the bike to respond similarly, but in a more controlled fashion. Now I've only ridden an sv650s, a cbr600rr, and my 954 and this reaction didn't seem characteristic of any of those bikes. What is going on here?
Is it:
A) That the tires were a little cold
B) Perhaps the concrete on these roads was extra smooth
C) The rear tire has a smaller contact patch than that of the litre bikes
D) A combination of the above
E) Other
The bike had about a 2 minute ride before the first loss of traction and the temperature was about 60 F. Though I can't recall at this moment, the road may have been asphault?
My brother mentioned that he has felt like the rear is going to come out before, but I don't think he really pushes it much, seeing as he just started riding. I told him to take it extra slow in the corners to avoid any accident like this, but I'd really like to know what it is that causes this on a 600 and not a litre bike. thanks! |
01-07-2006, 3:30 AM
Bike(s): CBR954RR Posts: 1,052
Rep:   (167) Rep Power: 7
| Re: R6 drifting What type of tires are on the R6 and how old are they? Also what tire pressure were you running in them? |
01-07-2006, 3:43 AM
| Re: R6 drifting not certain the pressure. Factory tires from new, about 2500 miles |
01-07-2006, 7:34 AM
Bike(s): '01 CBR929 Age: 49 Posts: 7,695
| Re: R6 drifting Probably a combination of tire condition, pressure, and temperature...
01-07-2006, 7:40 AM
Bike(s): FASTER THAN YOUR SISTER!!! Age: 27 Posts: 564
Rep:  (64) Rep Power: 3
| Re: R6 drifting HMM, i would think that your 954 under the same conditions would've responded similarly.... |
01-07-2006, 10:35 AM
Bike(s): YAMAHA R-1, WR450F Age: 43 Posts: 5,397
| Re: R6 drifting Called POWER,
Go YAMAHA!!!!!!!
Actuallly,  . Try it on the 'fiddyfour. Just be careful, lot more torque. |
01-07-2006, 10:40 AM
#7 | | Cliffs and twisties, sounds good.
Bike(s): '04 CBR1000RR, '84 Ascot, '02 RC51 Posts: 13,691
| Re: R6 drifting Quote: |
Originally Posted by Red Rider Probably a combination of tire condition, pressure, and temperature... |
Of course and RC would have buckled the pavement
01-07-2006, 10:44 AM
Bike(s): Puch Posts: 14,391
Originally Posted by sheepofblue
Of course and RC would have buckled the pavement  | Well, it is a heavy bike. |
01-07-2006, 10:53 AM
#9 | | Cliffs and twisties, sounds good.
Originally Posted by luvtolean Well, it is a heavy bike. | You don't sleep with it you ride it. Then it is about the torque
01-07-2006, 1:41 PM
#10 | | Das Ende ist hier
Bike(s): One Posts: 2,705
| Re: R6 drifting I've McCoy'd the RR a few times on cold tires. First time, I thought I had hit an oil patch on the road. |
01-09-2006, 1:24 AM
Originally Posted by Mojave954 Called POWER,
Go YAMAHA!!!!!!!
Actuallly,  . Try it on the 'fiddyfour. Just be careful, lot more torque. | I don't want to try that again, man. I couldn't really say that I had control at that point. When you're heading into a turn on someone else's bike, you don't really want to start seeing the ass end of it out of the corner of your eye. I exaggerate, of course, but that **** scared me!  |
01-09-2006, 11:38 AM
Bike(s): 2001 Honda CBR 929RE (Erion) Age: 26 Posts: 138
Rep:  (29) Rep Power: 4
| Re: R6 drifting I've had the 929 drift out on me like that before due to cold tires, but by 2 minutes in, you should've been mostly ok.
My vote is that they probably have too much air in them (read: smaller contact patch) and are a type that takes a long while to warm up. The pressures stamped on the bike are generally higher than what most people should actually run. |
