929 clutch friction plates - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 08-06-2013, 3:39 PM Thread Starter
Anyone have any idea how long a set of friction plates should last in a 929?
Ajsfwu is offline
post #2 of 7 Old 08-06-2013, 4:59 PM
Reputation Power: 113
Re: 929 clutch friction plates
Depends on how rough you are with it. I've never had to replace em in any of my bikes, and I do a lot of clutch wheelies etc. If you do a lot of drag starts, not so long.
Sky91 is offline
post #3 of 7 Old 08-07-2013, 3:49 AM Thread Starter
So 22k miles is not that much then?
Ajsfwu is offline
post #4 of 7 Old 08-07-2013, 3:58 AM
Reputation Power: 36
22k Not really. But depending on how clutch was used. Could wear a clutch in 60,000 or 4,000 depending on usage
Are you experienceing clutch slippage?
Rubber side down, One wheel to the sky for those who we won't forget. R.I.P homies miss you.
900rrHonda is offline
post #5 of 7 Old 08-07-2013, 4:05 AM Thread Starter
No, but when pulling away in first from a standstill and gradually letting the clutch out I feel four or five knocks from the engine.
Ajsfwu is offline
post #6 of 7 Old 08-07-2013, 4:29 AM
The life of the engine generally, say 100,000kms at least. Less than that probably indicates abuse.
post #7 of 7 Old 08-07-2013, 4:30 AM
Maybe a broken plate.
Pull the cover and have a look if you're concerned.
Do I need to remove the Clutch Housing when replacing the Clutch Plates? smithy954 Honda FireBlade 9 11-26-2011 1:47 AM
Clutch friction MTXMUGEN Honda FireBlade 8 07-03-2011 2:15 AM
What Clutch plates to use ? gr8scape Honda FireBlade 4 01-12-2009 1:24 PM
Ferodo Clutch Friction Disks kinkeringkong Honda FireBlade 1 01-16-2006 7:12 PM
Clutch Plates/Clutch Disk kinkeringkong Honda FireBlade 1 01-13-2006 8:46 AM
