How to Power Wheelie for Beginners - Honda Motorcycles - FireBlades.org
post #1 of 29 Old 08-19-2013, 9:11 PM Thread Starter
Hi Guys,
I've been improving on my wheelying the entire season and decided it is time to share some of the experience which I have gained with you lot, so that maybe it can save some of you some time when you are beginning to wheelie
Hope it helps and some can benefit from it
greetz,
Nico
s13nicotrico - my Youtube channel
Repsol_BG is offline
post #2 of 29 Old 08-20-2013, 3:36 AM
Re: How to Power Wheelie for Beginners
Originally Posted by Repsol_BG View Post
Hi Guys,
https://www.youtube.com/watch?v=RF1t4vnMT1U
greetz,
Nico
Nice video that I'm sure will help others.
But that is not a "power" wheelie.
You are bouncing it up using the forks.
A power wheelie is simply twisting the throttle.
post #3 of 29 Old 08-20-2013, 7:54 AM
Reputation Power: 291
Nice video
Irish's Blog Page
Hate this Skin
Assalam-o-Alaikum
setanta is offline
post #4 of 29 Old 08-20-2013, 11:17 AM Thread Starter
here we can agree to disagree i recon there are two main types of wheelie - 1. Clutch-up wheelie 2. Power wheelie .... hence - the one which I am showing doesn't use the clutch, so that does make it a power wheelie (now if there are different types of power wheelies I can't say, but it for sure is a power wheelie because no clutch is used )
greetz
Nico
ps: let me know if this worked for some of you learners like me
post #5 of 29 Old 08-20-2013, 11:23 AM
greetz
Nico
Sure, if you assume there are only two ways :-)
But I consider there to be three ways of wheelying a bike, power, clutch and bounce.
I agree with you, bouncing it up is probably the easiest and safest way to learn.
You don't seem to be changing gears yet though? In which case, why aren't you bouncing it up in second so you can run your wheelies further?
post #6 of 29 Old 08-20-2013, 11:34 AM
What do you reckon is the safest or easiest, up in 1st or 2nd?
Irish's Blog Page
Hate this Skin
Assalam-o-Alaikum
setanta is offline
post #7 of 29 Old 08-20-2013, 12:09 PM
Reputation Power: 113
It'll come up crazy fast in 1st if you give it too much welly ......
Sky91 is offline
post #8 of 29 Old 08-20-2013, 2:50 PM
What happens if your front wheel comes down crooked?
CBRER is offline
post #9 of 29 Old 08-20-2013, 2:56 PM
Depends how fast you're going and if you have a damper. Worst case - tank slapper/speed wobble causing you to come off. Best case, oil in the damper gets a bit warmer.
Sky91 is offline
post #10 of 29 Old 08-20-2013, 3:06 PM
The bike will buck as it forces the wheel back into line.
post #11 of 29 Old 08-20-2013, 3:09 PM
Personally, I consider first to be easier and safer for learning simply because your speed is so much lower.
post #12 of 29 Old 08-20-2013, 3:12 PM Thread Starter
Here is your answer How to power wheelie in SECOND gear
you can also run very far in first gear if you find the balance point, have very good throttle control and keep the bike between 7-10 k revs
post #13 of 29 Old 08-20-2013, 5:57 PM
Doing it now
Frozone is offline
post #14 of 29 Old 09-12-2013, 2:11 PM
THankyou!Great help, I think will try tomorrow!
shanes54 is offline
post #15 of 29 Old 09-12-2013, 2:29 PM
Until the engine dies of oil starvation or you run out of fuel .....
Balance point in first should NOT be tried by a newbie to wheelies though.
Sky91 is offline
2008 Honda CBR1000RR power wheelie Jharris Honda FireBlade 24 12-04-2010 1:16 AM
Did my first power wheelie coderedcbr Off-Topic 22 10-10-2005 10:40 PM
Lived my dream and did my first power wheelie!!! spark General Discussion 11 10-10-2005 1:22 PM
