What sensors and compnents does a 04 Cbr1000rr engine need to run - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 03-30-2014, 11:30 AM Thread Starter
I am building a hillclimber with the engine and can only get it to roll over. I want to shorten the original main harness. I have a wiring diagram from Haynes but, it seems to not be accurate because I can't locate the lean angle plug in; Any help Please
Cr500af is offline
post #2 of 6 Old 03-30-2014, 12:19 PM
Re: What sensors and compnents does a 04 Cbr1000rr engine need to run
You need all the sensors that are part of the injection, including the O2 sensor if it has one.
And you will need to so someting with the bank angle sensor, clutch and sidestand switches, and the ignition diode.
Oh, you probably need to do something with the exhaust and airbox valves as well.
post #3 of 6 Old 03-30-2014, 1:58 PM
Quoted: 4 Post(s)
Reputation Power: 77
Like br says you need it all.. I've put the engine in my 98 blade so have done it myself. Bank angle sensor is on the headlight loom. You also need the Hesd blank and exhaust servo blank or ecu will put the engine in limp home mode which means reduced power.
http://youtu.be/2ISgxtQXs9o
My 900RR Winter Project
Lambchops is offline
post #4 of 6 Old 03-30-2014, 2:13 PM
Glad you mentioned the HESD Lamb, completely forgot about that piece of crap :-)
post #5 of 6 Old 03-30-2014, 2:26 PM
Quoted: 4 Post(s)
Yes why you need limp mode if that fails I'm not sure... Don't need to worry about disconnecting pair sensor or flapper though those can be junked without issue
post #6 of 6 Old 03-30-2014, 6:23 PM
Quoted: 120 Post(s)
Reputation Power: 198
This is the OEM diagram. Hope it helps.
jondog9 is offline
Tags
cbr1000rr , issues , run , wiring problem , wont start
Engine weight CBR1000RR Unicorn General Discussion 6 11-01-2010 9:40 PM
Wanted: 98-99 CBR 900 RR sensors(speedo, and temp) lilrippy Wanted 2 02-12-2010 3:17 PM
what about the sensors on the original pipe that came with the cbr 1000 free1 Honda FireBlade 2 06-27-2007 8:52 PM
929 has 2 fan sensors ??????? hummm emazens Honda FireBlade 5 07-15-2006 11:48 PM
Bank angle sensors DaveM Honda FireBlade 6 02-09-2006 10:35 PM
