help!!! - Honda Motorcycles - FireBlades.org
post #1 of 15 Old 06-29-2014, 2:53 AM Thread Starter
Reputation Power: 6
help!!!
I have a 99 blade, and today on my way home, sounded and felt just like I had a dead cylinder. Checked spark plugs and coils, all have spark and work, all cylinders have compression, what else could it be???
andrewmartz22 is offline
post #2 of 15 Old 06-29-2014, 4:01 AM
Re: help!!!
All header pipes running at similar temps?
Checked the fuel pressure regulator vacuum hose?
post #3 of 15 Old 06-29-2014, 3:30 PM Thread Starter
Reputation Power: 6
Re: help!!!
cant check the header temps, it wont fire at all now. i dont think carbed engines have fuel pressure regulators?
post #4 of 15 Old 06-29-2014, 10:16 PM
Re: help!!!
Does it have spark still?
Oops, missed that :-)
Check the vacuum hose to the fuel tap is not sucking fuel.
post #5 of 15 Old 06-29-2014, 10:25 PM Thread Starter
Reputation Power: 6
Re: help!!!
Already checked for spark and compression, both good. You mean the vaccumm hose from the petcock to the second cylinder?
post #6 of 15 Old 06-29-2014, 10:28 PM
Re: help!!!
That would be the one.
post #7 of 15 Old 06-29-2014, 11:15 PM Thread Starter
Reputation Power: 6
Re: help!!!
completely dry. the hose i circled in red, is that supposed to go anywhere? since i got the bike its just been hanging behind the frame, not connected to anything. could that have something to do with it? the other pics just a little eye candy for ya im not sure i like the streetfighter look tho
IMAG00422.jpg‎   IMAG0038.jpg‎   IMAG0039.jpg‎
post #8 of 15 Old 06-30-2014, 2:30 AM
Quoted: 734 Post(s)
Reputation Power: 102
Re: help!!!
That set of hoses is the carb vent. Vents to atmosphere, and will occasionally dump fuel if bowls are overfilled or carbs are flipped over while removing. Does not connect to anything.
IanDoohan is offline
post #9 of 15 Old 06-30-2014, 2:53 AM Thread Starter
Reputation Power: 6
Re: help!!!
I saw a video on YouTube of a carb removal and the guy had to disconnect it from something. I checked the vaccumm line and it was dry, still have no idea what the problem is
post #10 of 15 Old 06-30-2014, 3:42 AM
Quoted: 734 Post(s)
Re: help!!!
Ok,'if you want to get technical then yes, the end of the hose sits in a small rounded steel hanger that should usually be attached the right frame rail, vented to atmosphere. The end of the hose is still open. Refer to bottom right of pic.
post #11 of 15 Old 06-30-2014, 3:44 AM Thread Starter
Reputation Power: 6
Re: help!!!
Hang on I'll find the link, it was definitely connected to something
post #12 of 15 Old 06-30-2014, 3:46 AM Thread Starter
Reputation Power: 6
Re: help!!!
At 1:20 he disconnects it from something.http://m.youtube.com/watch?v=EslWVIOKZWg
post #13 of 15 Old 06-30-2014, 4:31 AM
Quoted: 734 Post(s)
Re: help!!!
Ahhhh, so he does. Pardon my initial sarcasm, California model additional pollution control hoses, etc. My 93 and 99 non Cali models both vent to atmosphere as shown in my photo. Being from PA I would imagine you don't have that extra junk either.
When you checked the vacuum hose from cylinder 2 to fuel valve, if you remove it from the valve and add vacuum, fuel should flow from tank to carbs. Did you verify that?
post #14 of 15 Old 06-30-2014, 9:40 PM Thread Starter
Reputation Power: 6
Re: help!!!
Yes, fuel is getting to carbs. I think I had a clogged fuel line before the filter because I put it back together today and it started right up. Still definitely needs some work on the carbs tho, took it for a ride and it won't rev above 7k while At cruising speeds
post #15 of 15 Old 06-30-2014, 9:46 PM
Re: help!!!
Cali I think has to run the breathers into the airbox or cannister, but it doesn't do anything.
The vents do the same as your fuel tank vent, allow air in so the engine can draw fuel up the jets without creating vacuum in the float bowls.
Tags
1999 , blade , problem
