Help Help Help!!!! - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 11-08-2014, 2:50 PM Thread Starter
Low
Help Help Help!!!!
I am having serious problems with my 09 CBR 1000. When I press the ignition start button the bike will not start. I initially thought it was a problem with my battery. When pressing the ignition the bike makes a loud clicking or popping sound for a couple clicks and then it sounds as if it's going nuts. I recently replaced the battery and it made the sound stronger. I am thinking it may be a starter clutch problem or maybe the solenoid gone bad. Has anyone had this problem before?
Low is offline
post #2 of 3 Old 11-08-2014, 6:12 PM
Re: Help Help Help!!!!
If you suspect the starter solenoid as faulty give the solenoid a gentle tap with the handle of a screwdriver to see if it frees it otherwise check your wiring connectors.
Kevo954 is offline
post #3 of 3 Old 11-09-2014, 10:29 AM
Swing Low, sweet chariot, coming for to carry me home...
Low - did you lower your bike, or reference your under sea level location, or someone already took low&behold for a handle?
Damn vibrations. I second a loose connection issue. They're about as reliable as a levy in a storm.
blunt is offline
