Swing arm spools options - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 12-15-2014, 2:00 PM Thread Starter
hi guys. looking to use spools for raising the rear of the bike, but the 929 doesnt really have a place for them to go. Has any one used these before?
http://www.amazon.com/CBR929-CBR954-Shogun-Spools-Carbon/dp/B002TMUH50
how do they work ? are they reliable etc?
Thank you !
ChicoFireblade is offline
post #2 of 8 Old 12-15-2014, 10:50 PM
Quoted: 29 Post(s)
Re: Swing arm spools options
Those look like they will get pretty chewed up if you use them for lifting. If you can, just get some three inch long metric bolts for lifting and use the Shoguns for slide/tip over protection.
jdoni is offline
post #3 of 8 Old 12-15-2014, 11:01 PM
Quoted: 48 Post(s)
Reputation Power: 48
i have similar ones but not those exact ones. they work fine for me.
these are what ive got. 8mm is what you need. ive been using them with my stand a while n they arent chewed up. of course im pretty gentle when i put it on the stand though.
http://www.ebay.com/itm/1-Pair-Carbo...0d2a2b&vxp=mtr
954Kevin is offline
post #4 of 8 Old 12-16-2014, 1:22 AM Thread Starter
Ok sweet. thanks for the help. What do they bolt on to ? kinda hard to tell from the pics. would love to stop using the regular swing arm lift!!
post #5 of 8 Old 12-16-2014, 1:39 AM
Quoted: 48 Post(s)
well i was looking at pics online of the 929 swingarm n i guess it doesnt have a spot like my 954 to bolt them on. you can buy swingarm spool bung kits and weld them on though. i guess that would be the only solution.
954Kevin is offline
post #6 of 8 Old 12-16-2014, 1:44 AM Thread Starter
ok gotcha. i know a welder. Shouldnt be too tough. thanks for the help
post #7 of 8 Old 12-16-2014, 12:29 PM
Quoted: 48 Post(s)
yeah its a simply job to weld on the carrier for the spools. you should be able to find a simple kit on ebay or just do a search for one. should be cheap to get welded and cheap to buy the bungs to weld on. good luck n if you do go that route it would be cool if you throw a couple pictures up of the mod on here. might help someone else down the line with the same questions!
954Kevin is offline
post #8 of 8 Old 12-16-2014, 3:36 PM Thread Starter
yeah i will for sure. its a little down there on the priority list right now but it will be done at some point
thanks !
929RR swingarm spools/wheel stand options... giosoccer20 Honda FireBlade 10 06-26-2013 4:50 PM
Axle Sliders/Swing arm spools CBR929rr Knight5008055 Honda FireBlade 8 06-12-2012 11:17 AM
Swing Arm Sliders/Spools Red_hornet_AUS Honda Naked Sportbikes 3 03-16-2010 9:38 PM
929 spools tonga3 Honda FireBlade 20 05-04-2007 2:17 PM
Spools for da swing arm... showmethebombs Off-Topic 13 08-04-2003 1:40 PM
