Help - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 03-14-2016, 5:16 PM Thread Starter
Help
I just got a used but good oem rear shock for my 1998 cbr 900rr and something doesn't add up. When I put the shock on and bolt itin the bike sits too high. Help. I don't have the motor in the bike yet is that a problem. To my novice knowledge it shouldn't be that high. Please guys I need to help with this from a guy want to be an inspiring tech for Hondas I need some in site. Thanks Arthur
Arthur is offline
post #2 of 7 Old 03-14-2016, 5:46 PM
Re: Help
So, early blade shocks look similar, but are longer...
Fireblade shock lengths
CBR 900 RR 1992-1995 319mm
CBR 900 RR 1996-1997 305mm
CBR 900 RR 1998-1999 303mm
CBR 900 RR 2000-2001 286mm
CBR 900 RR 2002-2003 288mm
CBR 929 2000-2001 286mm
CBR 954 2002-2003 288mm
These shock lengths (courtesy of this or another forum) may help...
A few extra millimetres adds up to cms at the tail end...
1994 CBR900RRR
1997 CBR900RRV
saxonblade is offline
post #3 of 7 Old 03-14-2016, 5:48 PM
Re: Help
Have you got the right length shock?
If so, check the triangular plates are the right way round.....they are not equilateral triangles, more isosceles....
1994 CBR900RRR
1997 CBR900RRV
post #4 of 7 Old 03-14-2016, 6:02 PM Thread Starter
Re: Help
Thanks I think I was looking at it the wrong way I will try to move them around to get a better result. Well if that doesn't work how should I deal will it if the two results don't work. Different size shock or changing the plates I would need some serious help lol. Thanks guys Arthur
Arthur is offline
post #5 of 7 Old 03-14-2016, 6:38 PM
Quoted: 734 Post(s)
Reputation Power: 102
Re: Help
We've recently had this discussion here. It's very easy for Ebay sellers (not saying that's where you got your shock, but just as an example) to "think" they have a shock from 98-99 900's, when they have no idea that the 93-95 was longer, 96-97 was shorter, and the 98-99's were shorter still.
If you truly have a 900RR shock and your bike now sits too high, you have the older, longer shock from 93-95.
Generally when you swap out the shocks the triangles don't need to be removed, but if hey are as Sax said, there are directional arrows on them because they are not equilateral.
Plenty of able bodies here to help you out with whatever you 900 offers to drive you nuts.
IanDoohan is offline
post #6 of 7 Old 03-14-2016, 6:39 PM
Re: Help
See this thread..."Very high rear after replacing shock 1992 CBR 900"
1994 CBR900RRR
1997 CBR900RRV
post #7 of 7 Old 03-14-2016, 6:47 PM
Re: Help
I'm thinking most likely an early 1992-1995 shock...
But could possibly just be a shock that looks similar (or came off a blade - but was put there by someone else - rat bike/streetfighter etc)....
Or, when the shock has been changed, shock plates removed and not put back correctly....
(easily done, I have done this myself on an SSSA conversion.....where I ended up rotating the plates back to stock, and then making new triangular plates to suit - but if you are going to do this, the bikes geometry and rising rate suspension may not remain as Mr Honda intended)....
1994 CBR900RRR
1997 CBR900RRV
