954rr exhaust valve bypass - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 04-04-2016, 9:16 PM Thread Starter
Is there any benefit to buying a servo bypass module and undoing the cables to exhaust actuator.
phaney is offline
post #2 of 4 Old 04-04-2016, 9:45 PM
Heeza Y Zasch
unslow1's Avatar
Quoted: 388 Post(s)
Reputation Power: 59
Re: 954rr exhaust valve bypass
Kevin, you're up
unslow1 is offline
post #3 of 4 Old 04-05-2016, 1:48 AM
Quoted: 48 Post(s)
Reputation Power: 48
Originally Posted by unslow1 View Post
Kevin, you're up
lol. ill keep it short.
if its not throwing any codes like 34 or 35 leave how it sits. but expect failure at some point. the servo motor has some jankie ass plastic gears and they wont last long. mine failed somewhere around 10 or 11,000 miles on my 954. that was with the flapper already removed so the servo had less work than normal to do. my htev valve was in perfect smooth operation less any excessive carbon build up too. i opened the servo after i removed it and literally the teeth were sheared off 3/4's of the gears.
the bike wont make more or less power with or without the system using the stock exhaust. so the old mechanics saying applies here; if it aint broke dont fix it.
however, if, or when it does fail imo its a cheaper and easier fix to just buy the servo buddy or the vizitec unit i have on my 954 n remove all the servo, flapper and pin the htev in its mid way open position.
954Kevin is offline
post #4 of 4 Old 04-05-2016, 2:57 AM Thread Starter
Thanks for the great info. I'm a learning.
phaney is offline
02 954RR Pair valve block off plates 02CBR954AD Honda FireBlade 0 12-01-2014 12:30 PM
954rr severe bogging after pair valve and flapper mod Pipe General Discussion 14 07-17-2013 4:03 PM
HELP!!! 02 954rr, Oil comin out of the #4 pair valve port in exhaust port int76 Honda FireBlade 3 06-18-2008 8:33 PM
954rr valve maintenance interval? SquireSCA Honda FireBlade 2 02-06-2007 6:09 AM
Dropped valve on a '03 954rr azamora954 Honda FireBlade 12 12-23-2005 11:14 PM
